Old 07-07-06, 11:48 AM   #1
Tris
Default Brake Caliper Seal Kits
Is this expensive?
Front Seal Set £12.64ea
Rear Seal Set £21.19
If yes where to go please
Thanks
Old 07-07-06, 01:05 PM   #2
goof
I'm guessing the front's prices are per side, if so it's pretty standard: £25 for the full set of fronts.
Old 08-07-06, 04:04 PM   #3
petevtwin650
Or is it per piston for the front caliper
Old 08-07-06, 04:10 PM   #4
Scoobs
Seal kits are expensive for what they are.
Old 08-07-06, 04:49 PM   #5
Viney
Default Re: Brake Caliper Seal Kits
Originally Posted by Tris
Is this expensive?
Thanks
Id expect to pay £15 per piston including the piston and seals
Old 08-07-06, 07:25 PM   #6
21QUEST
21QUEST's Avatar
Is this expensive?
Thanks
Yep that's about right.
You can only buy the piston/seals as a complete set so probably better to look at it as £34.23(actual price) per caliper.
Ben
Nemo me impune lacessit.
Old 08-07-06, 08:43 PM   #7
jambo
jambo's Avatar
Just be thankful you have a total of 4 pistons up front, I have 12 and prices are about the same per piston. Am doing an exploritory strip and rebuild tomorrow re-using seals unless they look bad and will buy only the ones I need.
A lot of the time seals can be re-used once cleaned up in hot water andf re-greased but obviously if in any doubt, especially about hydraulic seals use new ones. Dust seals are slightly less critical especially in the summer.
Old 08-07-06, 09:06 PM   #8
lukemillar
I have just bought 2x 4-pot front caliper kits + 1 rear caliper kit from the US and the whole lot cost me around £25 I couldn't believe how much cheaper it was. Only downside is getting it shipped (most wont ship to non-US), though my sis lives in NY and she was has been home visting this week!
website is www.bellsuzuki.com with online fiche if anyone is curious for comparison.
Front Caliper Dust Seal mikebrooman SV Talk, Tuning & Tweaking 5 25-02-09 12:50 PM
Caliper seal Stu Bikes - Talk & Issues 15 20-01-09 05:35 PM
refresh caliper seal O ring? ejohnh SV Talk, Tuning & Tweaking 8 01-02-08 11:10 PM
Caliper Seal Kits? rscosworth SV Talk, Tuning & Tweaking 6 16-06-05 06:55 PM
Caliper Rebuild Kits and Pad Pins Xtrac SV Talk, Tuning & Tweaking 13 24-02-05 07:56 PM
