Old 11-07-06, 01:30 PM   #1
dotted
Default Torque - the math
Hi !
I need a ghetto dynometric tool to adjust my R&G crash bung , the are fixed to engine by 2 big hex bolts , big one has a torque of 93Nm , and small one 55Nm
Torque = r F sin(alfa)
- (Since sin(alfa)= sin(90º) = 1)
Torque = radius x Force
so:
Torque = wrench length * the strength i aply to it !
Wrench is 40cm long = 0.4m
Im 80kg ~= 800Nm
So if i have the wrench on the horizontal , and apply all my weight on the wrench end , the torque i apply to the bolt is:
Torque=0.4 * 800 = 320Nm
And to make 93 torque ,for the big engine bolt ,i just have to apply all my weight at:
x*800=93 ;x= 0.11m ;
i have to apply all my weight at 11cm from the bolt !
Does this make any sense ?
Taxi
Old 11-07-06, 01:34 PM   #2
Carsick
Looks about right, but good luck in getting it done right.
Where are you? I'm sure somebody local with be able to lend you a torque wrench.
Old 11-07-06, 01:38 PM   #3
chazzyb
Default Re: Torque - the math
I think you can guess the answer.
Old 11-07-06, 01:46 PM   #4
dotted
I'm to far away , Azores islands !
The aluminium frame doesn't look to flexible , I'm just afraid to stress the frame from over doing the bolts !
There are some reports of bent frames from crashes , i wonder if some of them are from over tight crash bungs !
Old 11-07-06, 01:48 PM   #5
John Burt
I doubt any body has bent a frame from over tightrening a bolt. I wouldn't stand on the wrench though, Just do the big one up tight about as tight s a car wheel nut, steel wheel and the other about half as tight.
Old 11-07-06, 02:00 PM   #6
timwilky
timwilky's Avatar
buy a torque wrench,
TBH I went for years without using one, and even now I use a torque wrench more as confirmation of my "feel".
Once you have stripped a few threads you get to know when you are getting close
Not Grumpy, opinionated.
Old 11-07-06, 06:15 PM   #7
SV Ste
Hi matey
just a quick point. there is no way that you could possibly bend the frame enough to permanently distort it by tightening a bolt. AS far as bent frames from crashes go, the bungs are only designed to stop your plastics, frame and other ancilliries from major damage in a lowish - maedium speed crash. They will not be effective unless really lucky) in a major fall.
Also looking at your calcs, if you try and put 320Nm through a bolt you will shear it or strip the threads in what you are inserting it into no worries. To give you an idea I tighten some 25mm bolts only too 195Nm on a hydraulic cylinder that transmits 11 tonne of force.
Old 11-07-06, 06:56 PM   #8
Blue_SV650S
Ahhh science in action ...
Your theory is sound, but I feel you are better off applying a smaller weight but with a longer moment. I have no idea how you would accurately place you body weight at 11cm from the fulcrum!!
How about this … fill a bucket with some water until you have say 10kg of water (inc bucket), you can measure this on some scales, or do the rough math, water is 1kg per litre. You will then be able to measure a leaver and attach the bucket at the appropriate point. Much less room for error than using yourself as the load!!
Old 11-07-06, 10:12 PM   #9
wheelnut
How can anyone whether they are American or not use a word like MATH?
It is plural :P Mathematics or MATHS
Old 14-07-06, 06:46 AM   #10
John Burt
So if there are two of you does that make you Malcs ?????? :P
Torque really necessary? MCN_LiamM Bikes - Talk & Issues 38 23-05-09 12:58 PM
which torque arm dizzyblonde SV Talk, Tuning & Tweaking 11 25-01-08 01:38 PM
low end torque + up top h/p florida650 SV Talk, Tuning & Tweaking 4 30-07-07 08:59 AM
polished torque arm adey Stuff Wanted 11 16-01-06 11:18 AM
what does torque mean!?!?!? didge SV Talk, Tuning & Tweaking 63 04-07-05 07:49 PM
