Old 24-07-06, 02:08 PM   #1
mann650
Default yet another won't start, 01 650
Ok as far as I can tell through searching this is one that no one has had yet. I have an 01 sv 650s with 18k on it. 3 weeks ago it didn't start up on the first few cranks as it usually does. Instead it took about 20 seconds of cranking to fire. this problem is getting worse and increasing in frequency. I can smell some gas from the exhaust while cranking but don't know if it is too much or too little it is just there. When it finally does start it runs fine and even if I crank the throttle to see if it was flooded or close to it, it raps up just fine. It seems to be a problem if the bike is cool (sitting for more than 5 hours). This problem will come and go and is un-affected by enricher position or throttle position so I am thinking electrical but am not sure what may be causing it. Let the guessing begin...
Old 24-07-06, 08:44 PM   #2
klohiq
have you checked your plugs and wires?
Old 24-07-06, 08:56 PM   #3
Biker Biggles
Biker Biggles's Avatar
Does it need a service?Have you got a tankfull of **** fuel?Is the air filter clogged with crud?
Old 25-07-06, 01:23 PM   #4
mann650
the fuel seems to be ok because I haven't had any problems out of the other bike filled up with the same stuff on that day. I'm in the process of checking the plugs now and will get back with you on what I find. as for service the standard stuff has been done is there a specific service for this type of problem and if so what is it?
Old 25-07-06, 03:54 PM   #5
wyrdness
Definitely check them. Old HT leads can cause this kind of problem and are harder to check than plugs. If they've been on the bike for a few years, then I'd suggest replacing them.
A sad start to the day ooger Idle Banter 17 03-06-08 11:27 AM
Bad start for the day timwilky Idle Banter 13 22-04-08 09:52 AM
Wont start, but will bump start :( Wally SV Talk, Tuning & Tweaking 6 10-08-07 02:02 PM
She won't start! Help! Bear SV Talk, Tuning & Tweaking 43 19-12-06 11:39 AM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
