Old 18-12-06, 09:53 PM   #1
Bear
Default She won't start! Help!
So I'm wending my merry way home from work this evening when I notice an unusual noise from the bike when pulling away. Sort of a tapping/flapping noise that seems to be coming from the rear tyre. Stopped the bike to check it out and was rolling the bike back and forward to check both tyres (nothing there to the naked eye) when I knocked it off the side stand and it started to fall
Luckily I am part gorilla, so managed to heave it upright from the awkward position I found myself in. As I was doing so the engine was revving really high, so I switched it off before going for the final push.
Got it back upright and went to start her up again; nada. The red warning light and oil pressure indicator came on , and all that happens when I push the switch is that my lights dim. Manage to push start it, all is going well, bloody noise starts up again. "Aha!" thinks me, being a clever sort : I'll wait until I'm at the top of a hill, check the if it's a tight spot on the chain, and then if it won't start again I'll push it down the hill and ride it home. It's not the chain. It now won't start even when rolling at up to 20mph...
So now I'm no closer to finding out what the noise is, and I have a bike that won't start . Any suggestions?
BTW, it's a k5
Old 18-12-06, 09:55 PM   #2
fizzwheel
fizzwheel's Avatar
Have you knocked the kill switch ?
Old 18-12-06, 09:57 PM   #3
Sudoxe
Tip Over Sensor come loose? But that should give you an FI indicator on the LCD.
Dan
Old 18-12-06, 10:03 PM   #4
Bear
No, kill switch is first thing I checked. What's the tip-over sensor, and is there a way to reset it?
Old 18-12-06, 10:05 PM   #5
21QUEST
21QUEST's Avatar
Connector for the clutch switch unplugged?
Ben
Nemo me impune lacessit.
Old 18-12-06, 10:05 PM   #6
Bear
Only indicator is the oil pressure indicator. Loads of oil in there, tho! Maybe an oil pump/pressure sensor issue? Would that stop the ECU from allowing the bike to start maybe?
Old 18-12-06, 10:07 PM   #7
Bear
Ben
As far as I know I checked every connection I could find. Whereabouts is that one? Lights are still dimming when I hit the switch, so it's registering that something's happening
Old 18-12-06, 10:16 PM   #8
netsurfer
Not sure if the switch is in the same place on the K5 - on my K1 its just in front of the clutch lever - you cant miss the pair of wires going onto it. Easiest way to rule it out, try starting with the clutch out (in neutral of course) if the lights dont dim then the switch is more than likely OK
Lights dimming would to me indicate that power is getting to the starter motor.. after the bike being dropped, the 1st thing I would think would be engine oil in one or both cylinders. However since the bike was running after it was dropped then you could almost rule that out (could try taking plugs out and see)
And as I've stressed on here before... attempting to turn the engine over with oil in one or both cylinders could lead to all sorts of problems like bent con-rod or head gasket probs.
Pete
Old 18-12-06, 10:23 PM   #9
Fearg
Clutch switch would be top of my list, had the same thing happen to me well similar anyways :P
Old 18-12-06, 10:24 PM   #10
netsurfer
Doubtful, if the lights are dimming
Just my £0.02
Pete
A sad start to the day ooger Idle Banter 17 03-06-08 11:27 AM
Bad start for the day timwilky Idle Banter 13 22-04-08 09:52 AM
Wont start, but will bump start :( Wally SV Talk, Tuning & Tweaking 6 10-08-07 02:02 PM
yet another won't start, 01 650 mann650 SV Talk, Tuning & Tweaking 4 25-07-06 03:54 PM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
