Old 29-08-06, 10:15 AM   #1
Kinvig
Default Tiem requried to fit exhaust?
Right, my exhaust didn't arrive over the weekend, which is quite annoying!!!!
I'm hoping that it'll arrive tonight. Question is: How long would it take to fit?
I can't take a sick day so a leisurely day donig it tomorrow is out of the question.
Think I've got all the tools I'll need:
Hacksaw
Spanner
Exhaust sealant stuff
metal tape measure
Could I get it done in say 3 hours (max) tonight? It's just a bit of sawing right?
I'll worry about unrivetting the baffle at the weekend.
Dirk
Old 29-08-06, 10:19 AM   #2
fizzwheel
fizzwheel's Avatar
3hrs is plenty of time
Old 29-08-06, 10:26 AM   #3
Scoobs
An hour should do it.
Old 29-08-06, 10:33 AM   #4
timwilky
timwilky's Avatar
forget the hacksaw, use an angle grinder or air saw if you have access to one. far quicker and neater
Not Grumpy, opinionated.
Old 29-08-06, 10:55 AM   #5
tricky
I did mine with a Dremmel, got through about 4 cutting disks, but still much quicker than a hacksaw.
Old 29-08-06, 10:57 AM   #6
jim@55
if ure using a hacksaw then itll take a while to saw it ,use an angle grinder ,gets through it in next to no time
Old 29-08-06, 11:00 AM   #7
Kinvig
hacksaw only for me.
Now "Air saw". does that use the same materials as an air guitar? ;o)
I'll get me (air-)coat.
Old 29-08-06, 11:04 AM   #8
Viney
20 mins. DONT USE EXHAUST SEALENT. Use std Bathroom silicone sealent.
HTH
Old 29-08-06, 11:14 AM   #9
Kinvig
HTH
Hi Viney,
Why bathroom sealant?
Dirk
Old 29-08-06, 11:21 AM   #10
grinder is the way to go! zero effort! i didnt use sealer, it leaked abit at first but black exhaust shi# must have blocked it from the inside cuz it dont now.
plus sealer will make it harder to remove if ever you have to take it off again.
gasoline in my exhaust... fuel in my exhaust mtb83201 SV Talk, Tuning & Tweaking 5 29-04-08 10:58 PM
Exhaust 4 exhaust swap? SVnutta!! SV Talk, Tuning & Tweaking 2 29-06-06 04:26 PM
New exhaust what about the re-map. lew893 Exhausts 1 30-03-06 06:47 AM
Which exhaust? Franco1 Bikes - Talk & Issues 23 29-03-06 07:54 AM
