Old 07-09-06, 06:50 AM   #1
Kinvig
Default Fitting an exhaust Pt I
Well, just about everyone has given me some advice on this so I thought I'd share the results:
Photo 1:
Make sure hte exhaust is cold. Your skin is good for determining this - lots of nerve endings & feelings.
Photo 2:
One last look at the bike before sawing commences.
Photo 3:
Mark a line 5cm from the weld. Stick a bit of wood between the bike and the swing arm & remove the rear hugger.
Photo 4:
After making a groove with the saw in hte correct location. I then sawed from over the bike seat - I'm left handed & it was easier this way. Exhaust came off after 30-45 mins up/down hand action. Would have bee nquicker without the audience of non-believers i.e. Next Door neighbour & pizza delivery guy.
Got an avi file but I'm not sure how to upload to hear hte sound of the "nekkid" bike.
The exhaust is off the bike but I need to go buy a file to file down the burrs. Part II of this experience to follow!
...and does anyone know what the foot rest thingy that I scratched is called. Oops!
Dirk
Old 07-09-06, 07:44 AM   #2
Kinvig
This *may* work:
Click on this link for my bike sans exhaust.
Works now! Goddammed, pedantic Unix-based systems!
Old 07-09-06, 07:47 AM   #3
Scoobs
Originally Posted by Kinvig
This *may* work:
Or not
Old 07-09-06, 07:53 AM   #4
TSM
The Sick Man
TSM's Avatar
Its called a 'heel plate', you should have removed the rear set and moved it out the way, it would have made the cutting easier.
Old 07-09-06, 09:18 AM   #5
Jdubya
*In Hindsight*
Old 07-09-06, 11:18 AM   #6
Terence
Cool, I'm inspired
Think I'll use an angle grinder though...
Old 07-09-06, 01:20 PM   #7
fullstop102
Thats why God created a dremmel set! :P
Small neat and does a good job!
Old 07-09-06, 01:29 PM   #8
TSM
The Sick Man
TSM's Avatar
Have you use it on the sv pipe? Its double walled so will cause a little issue.
Old 07-09-06, 02:14 PM   #9
tricky
I did mine with a Dremmel, no bother at all, just need to get the big (40mm ?) reinforced cutting discs, although I did end up using about 3 of them.
Old 07-09-06, 03:09 PM   #10
Spiderman
Where the hell am I?
Spiderman's Avatar
Ah reminds me of doing mine. And i think (hope) everyone has started thier bike and reved it a bit without the can on. Its just ine of those things you gotta do innit?
Fitting A New Exhaust sid99 SV Talk, Tuning & Tweaking 28 03-10-08 07:17 PM
Fitting an exhaust to a K7 shonadoll SV Talk, Tuning & Tweaking 7 29-08-08 07:18 PM
fitting exhaust sv650nutter149 Thames Valley 4 22-09-07 08:59 AM
Exhaust fitting Born again SV Talk, Tuning & Tweaking 3 19-04-07 02:47 PM
ART Exhaust (fitting) xlewdx Exhausts 8 17-12-06 07:06 PM
