Old 11-09-06, 07:20 PM   #1
paulthewitt
Default Coolant levels on a Pointy
did a search and only found stuff on curvies...
i have a pointy k3
Question part 1:
basically, how do i know when my coolant is low? where is the sight glass thing for it? at this point any pics would be appreciated.
i basically found a new resevoir bottle thingy and it seemed low on whatever goes in it, i believe it to be coolant but am not sure.
Question part 2:
am i ok to just top up the coolant with some of the halfords premix stuff? the bike is only 3 years old with 9000 miles on it, so can i avoid a full system drain?
Thanks
Paul
Old 11-09-06, 07:58 PM   #2
are you sure its low? there is a max and a min mark on the expansion bottle its ment to not look full. ive got a k3 with 6200 miles on and ive never had to touch it.
Old 11-09-06, 08:06 PM   #3
Red ones
Red ones's Avatar
Pop it on a paddock stand and lift the tank. The resevoir is on the LHS of the tank and it capped with a rubber bung.I have had to added the grand total of 50ml after 14,600 miles on my K5
I don't think I have ever met anyone who has drained the system. All system can take the same premix stuff, or if it is only a minor top up (L to F is minor) then purified water will do.
Old 11-09-06, 08:10 PM   #4
paulthewitt
not sure, thats why i wanted to know where to look (whether this bottle i found is the coolant)
also my engine was replaced at a garage (blew up ) so they may have not filled it fully, rather than it using loads.
Paul
Old 11-09-06, 08:37 PM   #5
as red ones said thats the expansion tank for the coolant, top it up and keep an eye on it.
Old 11-09-06, 09:12 PM   #6
bobit69
Would your engine run hotter if your coolant was buggered? As I have my K3 has benn running hotter than normal.
Old 11-09-06, 09:52 PM   #7
how hot? mine runs when hot between 92 and 98
Old 12-09-06, 07:52 AM   #8
bobit69
Don't want to say as it isn't that hot... 89-97 Although you could put it down to the humid weather.
Does coolant deteriorate? And or there any point in replacing it periodically?
Old 12-09-06, 07:57 AM   #9
lukemillar
I changed my coolant after 2 years as recommended. I don't know whether it needed it or not - but I assume it deteriotes given this timescale. Premixed coolant costs very little so why not.
If you do it, then you quickly realise why nakeds are better the radiator filler cap is underneath the fairing on the right-hand side, which you have to remove to get to.
It's not really a difficult job to do, and quite useful because you will learn a little more about your bike which in my mind, is always a good thing.
dB levels Mike2165 Track Days 6 14-02-08 12:45 PM
Cholesterol Levels Richie Idle Banter 7 09-12-07 10:52 PM
green/blue coolant in k5 pointy (naked) sv650nutter149 SV Talk, Tuning & Tweaking 1 08-05-07 12:03 PM
Now this is wrong on so many levels … Blue_SV650S Idle Banter 50 04-05-07 10:20 AM
Oil levels TC3 SV Talk, Tuning & Tweaking 6 23-01-06 08:34 PM
