Old 14-09-06, 02:08 PM   #1
Sheila
Sheila's Avatar
Default Oring Lube??
Anyone using Wurth High performance Dry chain lube?? If so is it any good??
Just been sold a can of it and wonder if its okay for O-ring as it doesn't say on can whether is or isn't...
Sheila's Wheels..
SV650S K6 Candy Napolean Blue
Sheila is offline   Reply With Quote
Old 14-09-06, 02:12 PM   #2
Carsick
Some people use it, more than a few have said they like it.
It's fine for o-rings, all modern bike chains are o-ring or some variation on the idea of a rubber seal between links.
Old 15-09-06, 10:15 AM   #3
Nashwan
I use it and, like Tony the tiger, I think it's grrrrrrrreat. It doesn't fling much, doesn't pick up a lot of muck, is easy to apply and does a good job of protecting the chain.
Old 15-09-06, 10:35 AM   #4
Banus
Default Wurth
I have used it and will continue to use it since it came out on top in a recent RiDE survey.
Just about zero fling over your rear wheel and priced competitively aginst its rivals.
The only problem is that as its a "dry" lube and comes out with the consistency of a deorderant aerosol, you can't really tell how much you are putting on and you can overdo it as you cant actually see that your chain is lubed
Old 15-09-06, 10:45 AM   #5
lukemillar
I use this stuff as well. Busters recently sent me 2 cans of Silkolene race lube (instead of silkolene pro cool!?) I didn't bother sending them back because I had just run out of the wurth stuff. Looked sort of similar - no directions, so I merrily spray this stuff on. However after a few minutes the stuff goess super sticky - Like fly paper. Not only did evry single bit of cr@p from the road stick to it, so much of it flicked of that it completely basted my rear wheel.
Needless to say a bath in some paraffin and another can of wurth stuff and things are looking much better now!
Oh, I now have 2 cans of Silkolene race lube going free to a good home (I'm not joking!) If anyone wants this stuff, then drop me a PM and i'll pop a can in the post.
Old 15-09-06, 11:23 AM   #6
jambo
jambo's Avatar
Wurth Dry chain lube is good stuff, I just found it a little tricky to work out when it needed some more (it's clear you see....) sure I could have worked it out with time but fitted a scottoiler instead...
Old 15-09-06, 03:42 PM   #7
Jdubya
Yep, works a treat...I've been using nothing but this stuff for a while now.
Old 15-09-06, 03:59 PM   #8
svrash
Nuff said!
How much lube? (Chain lube!) AndyL SV Talk, Tuning & Tweaking 10 10-01-09 08:04 PM
Do I need to lube up?? DoubleD SV Talk, Tuning & Tweaking 2 12-06-08 10:52 AM
Wax or Lube?? Morpheus Bikes - Talk & Issues 26 18-03-05 06:55 PM
What lube do you use? chutz SV Talk, Tuning & Tweaking 26 09-03-04 01:37 PM
Wax or Lube?? chewy22 SV Talk, Tuning & Tweaking 23 04-01-70 03:38 AM
