Old 19-09-06, 06:15 PM   #1
BILLY
Default Front brake discs
Is there anyway of tightening the disc on the carrier as one of mine has come loose and clunks when I brake. Just to note they are TL1000 discs on my SRad from end conversion. Any help will be appreciated.
BILLY
Old 19-09-06, 06:30 PM   #2
TSM
The Sick Man
TSM's Avatar
Your bobins are worn out, i have the same problem at the moment. Unless you can find a company selling you these bobins you are stuck to get new disks.
Old 19-09-06, 07:08 PM   #3
BILLY
Is it dangerous to carry on riding with them like that?
Old 19-09-06, 07:17 PM   #4
TSM
The Sick Man
TSM's Avatar
Depends on how bad they are. Mine are so bad that sometimes i get banging when braking at under 20mph.
Old 19-09-06, 07:21 PM   #5
BILLY
Just a clunk at the moment
Old 19-09-06, 08:12 PM   #6
speedking
There is no way to tighten them up. If they were aftemarket rotors you could likely replace the floating pins but even then the chances are that the carrier and/or rotor would still have too much play.
I've got a used set of EBC Prolite rotors with very low miles on them if you are interested. They are the TL/SV1000 fitment rotors that will work with your conversion. New they run $220-$240 each, I'd take $265 for this pair. PM me for more info.
--Speed
Old 19-09-06, 08:28 PM   #7
jambo
jambo's Avatar
As long as you mean that the disc bolts are tight and the braking surface is moving on the carrier you can get rebuild kits:
http://www.stealthproducts.co.uk/products/discs.php
Not sure on the equipment needed to fit them though, and if there is wear on the carrier this may not help. Also not sure if as stated above that you can rebuild standard disc.
Old 19-09-06, 09:42 PM   #8
svrash
My pads move in the calipers, making a clunk
Old 19-09-06, 09:58 PM   #9
BILLY
Originally Posted by svrash
My pads move in the callipers, making a clunk
It's definitely the disc you can grab hold of it and move it on the carrier and see the movement!!!
Old 20-09-06, 08:05 AM   #10
21QUEST
21QUEST's Avatar
Billy My personal opionion is just get new ones. My experience with the EBC Prolite is that you have a build up of rust when not used even for a day or two(something to do with high iron content or something) You could go for that or any other after market ones that peeps say are good but I would check with the manufacturers regarding stability with regards to that issue when not used for a while. OE tend not to have the problem and same as the 'Braking' wavy discs I have.
Sometimes it can be difficult getting good used ones and you just end up wasting time(and money if really unlucky) mucking around. Sure you can get good used ones but I have had my fair share of dodgy ones from breakers and now more inclined to get new.
If you decide to get new, get some prices and let me know via PM. I may be able to help.
Ben
Nemo me impune lacessit.
Brake Discs for a front upgrade drag Bikes - Talk & Issues 24 30-04-09 10:52 PM
Front Brake Discs Olly For Sale - SV's and SV related items 3 23-06-08 04:42 PM
Brake discs for GSXR front end andyb SV Talk, Tuning & Tweaking 5 07-06-07 08:41 PM
Pointy SV650 front brake discs Ter Stuff Wanted 0 23-02-07 04:51 PM
Brake Discs for GSXR front end conversion on SV 320mm discs Ter For Sale - SV's and SV related items 0 22-09-06 04:50 PM
