Old 24-09-06, 02:46 PM   #1
hovis
Default service?
my 99 curvy has done 13000 miles & had 4 services
1st service 23/7/99.628 miles
.................13/05/00.4200m
.................12/06/02.8900m
.................6/04/06.12000m
so the will next service be a major one? my bike has been serviced every 4000miles is this the norm? i will do the minors myself,but what should be done at 16000(how much££)
the garage has quoted £120 for braided hoese all round(i cant stand bleeding brakes) but what else should be done??
Old 24-09-06, 08:31 PM   #2
BILLY
Valve clearences checked and ajusted if ness.
Old 24-09-06, 08:38 PM   #3
fizzwheel
fizzwheel's Avatar
I think Liz paid around £185 for her 16500 mile service. As Billy says, Valve Clearances are the main thing with this one plus all the other usual stuff.
When were the hoses last changed ? Haynes manual says change the brake fluid every two years and change the hoses every 4.
£120 seems a bit steep for braided hoses.. but I havent got anything to compare the price with.
Is this the same garage that charged you for 3 batteries in the same week and flogged you a dodgy reg /rec ?
If so I wouldnt touch them with a barge pole, I'd be going somewhere else to get the work done.
Old 24-09-06, 08:43 PM   #4
hovis
i dont think the hoses have ever been changed.
i only had 1 dodgy battery & that was not from him but the reg was, which i will get a full refund for
Old 25-09-06, 07:41 AM   #5
Viney
A set of hoses cost about £60, so they are charging you £60 to fit them! Thats about 2 hours labour, which is about an hour more than it takes.
Old 25-09-06, 07:47 AM   #6
lukemillar
Depends on what brake line setup they are going for and which hoses they plan on using. I have seen Some 3 line kits closer to the £75-80 mark which would leave about £40 to fit them. I thought labour was closer to £40 a hour (Or is that just in London ). Doesn't seem overly expensive to me
what do i need for a DIY service? chompy SV Talk, Tuning & Tweaking 20 04-03-09 11:18 PM
Service my SV ukrobuk Bikes - Talk & Issues 1 19-02-08 08:59 PM
Citizens Service - the new National Service. grh1904 Idle Banter 11 06-09-07 11:44 AM
Service Manual for SV650S 2001 and Service Recommendation stone SV Talk, Tuning & Tweaking 1 09-05-07 04:20 PM
first service macdo Pennine Massive 5 09-09-05 06:45 AM
