Old 03-11-06, 11:21 PM   #1
Default how much for a new front end?
how much would it or should it cost to replace the front end on my bent sv with used parts?
after a closer inspection the bottom yoke is bent so i'd need everything from the head stock forward.
Old 04-11-06, 12:08 AM   #2
Stu
Trinity
Stu's Avatar
See SVrash's costing sheet - looks like you get Gsxr upgrade for the same price
http://forums.sv650.org/viewtopic.ph...ght=gsxr+front
Old 04-11-06, 12:13 AM   #3
Yep, if buying used you could almost certainly do GSXR for less in fact, SV bits are in higher demand it seems. I sold my SV bits for more than I paid for my GSXR bits...
Old 04-11-06, 12:16 AM   #4
Stu
Trinity
Stu's Avatar
Or Motoliners to straighten everything?
If bizarrely you didn't want the upgrade
Old 04-11-06, 12:23 AM   #5
BILLY
Same here!!
Old 04-11-06, 09:04 AM   #6
cheers
Old 04-11-06, 09:19 AM   #7
Biker Biggles
Biker Biggles's Avatar
Take a good hard look at the frame before you do it.Any distortion around the headstock and it's scrap.
Old 04-11-06, 09:26 AM   #8
SV650Racer
My friend is selling a complete frond end complete with forks which have Ohlins springs and Emmulators fitted and wavey discs. PM me if your interested and i will find out how much.
If you go for a GSXR front end then go for the K4/K5 600/750 plonks straight in pretty much and has the radial calipers and with stock internals the forks work perfect.
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
Front Discs (pair) for sv650 '99 curvy + Front wheel mikeSV Stuff Wanted 1 28-05-08 04:21 PM
Front Discs, For those with GSXR Front Ends on thier SV's Ter For Sale - SV's and SV related items 2 14-03-07 12:56 PM
SV650s 2000 model, yellow. I need front central and front right fairing. OdySV Stuff Wanted 0 25-02-07 04:47 PM
K3 radiator(any condition), front header pipe, FRONT END!!!! buttmunch Stuff Wanted 1 10-04-06 10:09 PM
