Old 07-01-07, 08:29 PM   #1
Stu
Trinity
Stu's Avatar
Default Can't undo Wheel nuts
Tried to undo the rear wheel bolts, but the chain guide just spun.
Will take it to a dealer's to hopefully help.
Happened to anyone else?
Old 07-01-07, 08:35 PM   #2
John Burt
Pretty sure that this has happened to a few others, did you have a socket on the other end of the spindle (bolt head) this would stop that happening.
Old 07-01-07, 08:38 PM   #3
dirtydog
Knob faced knobster
dirtydog's Avatar
looks like the spindle was just spinning?
Did you have a socket or spanner on the other side?
dang it was beaten to it again
2011 Speed Triple 1050
Old 07-01-07, 08:39 PM   #4
Rich
Rich's Avatar
those chain guides are a mennis, they never line up like u think they shud and urs has well, gone for the 360.. what u need is a bucket of wd40, a torque wrench and a scaffold pole for extra leverage good luck wi gettin it sorted,,sorry wunt much help!!!
RIP Hovis - Unlucky Boyo
Old 07-01-07, 10:05 PM   #5
mine did this when tightening up and put a loverly groove in my swing arm as others have said a socket on the other side sorts this.
Old 07-01-07, 10:21 PM   #6
busasean
EH? are we texting now?
try a spanner on each side of the spindle. the adjuster guides are ****e and might as well be made of tin foil. i've scratched my swingarm trying to undo the poxy nut. i normally wedge a srewdriver under the swingarm, against the guide to stop it spinning. bloody difficult with only two hands though!
Old 08-01-07, 12:09 AM   #7
Stu
Trinity
Stu's Avatar
Thanks, all
You can see the circular scratch I now have at the very end of the swing arm
yes a socket each side would work, but not easy with one person putting all my effort into getting it to move and the right side nut is so narrow the spanner just wants to slip off now.
Dealers here I come.
Old 08-01-07, 12:11 AM   #8
You can sort of balance a breaker bar on the nut in such a way that it won't come off... Hard to explain, it's all just about bracing it right.
Old 08-01-07, 12:25 AM   #9
Stu
Trinity
Stu's Avatar
I was going to brace a spanner against the swing arm crash bung, but as the spanner was starting to slip on the right side I gave up.
Is the OE tool kit crap or something? I thought you couldn't beat a six sided closed end spanner
Old 08-01-07, 12:39 AM   #10
Fearg
same thing happened to me when I first tried undoing the nut. Ended up having bike on Abba stand socket and torque wrench on nut side and bolt head side, then turned the bolt rather than the nut just a turn or two to free it up. Came off ok after that. Put plenty of copper slip on the nut face before re-assembling. No copper slip on the threads though it will bugger up the torque settings
Red Ken is nuts Dicky Ticker Idle Banter 34 24-07-07 09:25 PM
Am I going nuts..... colinbal4 SV Ecosse 4 16-08-06 05:16 PM
Only if your nuts Dicky Ticker The Essex Lounge 5 20-11-05 03:00 PM
new nuts. Warren SV Talk, Tuning & Tweaking 24 23-03-05 09:09 PM
Oh Nuts! admin SV Talk, Tuning & Tweaking 19 14-11-04 05:21 PM
