Old 25-01-07, 11:48 AM   #1
hovis
Default scottoiler setting?
what is your oiler set to?
i have differant size drips instead of number, so mine is on 4.....but not tested it out yet
(i think this has been covered a bit b4 but could not find it in the search)
Old 25-01-07, 11:57 AM   #2
thor
Depends. Ride it a bit. If the chain is dry, turn it up, if it's flinging, then turn it down.
If it's wet it will need more.
There's no substitute for checking your chain regularly.
Old 25-01-07, 12:05 PM   #3
chazzyb
Mines's doing about two drops a minute. Setting is towards the higher end of the range. I have ended up with quite a long delivery path, that's not got much drop for quite a long distance. My bottle's under the seat on the right. The delivery tube comes forward along the sub-frame top rail, then down to the swinging arm pivot near the brake master cylinder, across the swinging arm to the chain side and along the underside of it.
Old 25-01-07, 12:06 PM   #4
fizzwheel
fizzwheel's Avatar
I tweak mine until the chain is wet and theres some fling on the back wheel and then I turn it down a little.
Flow rate depends on temperature etc so you need to keep adjusting it in order to make sure your chain is lubed properly. Every bike is different so you'll need to fiddle with it to suit your bike.
Old 25-01-07, 12:07 PM   #5
embee
embee's Avatar
...or buy a Deauville...........
Coat time.
Old 25-01-07, 03:39 PM   #6
Default Re: scottoiler setting?
Differences in the specific installation make changes to the required setting to give the same oil flow, therefore any one else's setting is meaningless to you, even on the same bike with the oiler in the same place.
Scottloiler recommend a setting that gives two drops of oil a minute, bend the oil feed tube away from the sprocket and with the bike ticking over time roughly how long between drops. I find that's normally a bit high, but it's a good place to start and it'll get you in the right sort of area. Remember the chain shouldn't be dripping with oil, the benefit of an oiler is that it's constantly metering oil to the chain, not spraying loads on that gets gradually lost as time passes like spray on lube does.
Old 25-01-07, 07:47 PM   #7
New Leaf
mine is set at 7 to 8 at the moment.
the cold weather seems to really slow it down. Also adding my lube tube seemed to slow it down too. - it was set at 5-6 before then.
In the summer i found that setting 3 was enough.
SV Clock Setting? SV-net SV Talk, Tuning & Tweaking 1 08-07-08 12:34 PM
Self setting record KillaSV SV Talk, Tuning & Tweaking 3 08-05-08 11:34 AM
scottoiler setting ?(flow rate ?) hovis Bikes - Talk & Issues 29 14-03-07 02:49 PM
setting up a veypor tomjones2 SV Talk, Tuning & Tweaking 4 21-05-06 11:03 AM
Torque setting? skidmarx SV Talk, Tuning & Tweaking 8 10-09-05 08:31 PM
