Old 07-03-07, 07:07 PM   #1
haggis
Default Wheel spacer dilemma.... (and now front wheel dilemma!)
I'm putting new bearings in my wheels just now. The rear has gone in as planned.
Can someone explain why my front wheel spacer between the bearings is shorter than the gap between the bearings? It's 22.5x73mm
I've not done the job yet but the distance between the bearing seats is more than 73mm, the length of the spacer. Why?
Old 07-03-07, 07:37 PM   #2
21QUEST
21QUEST's Avatar
Default Re: Wheel spacer dilemma....
Sounds a silly question but are you sure you have measured it correctly. The spacer you have is the correct size and the distance between the bearings(where they sit in wheel) should be about 73mm give ot take a few wotsit. I'll say check again.
Ben
Nemo me impune lacessit.
Old 07-03-07, 08:14 PM   #3
haggis
Thanks Ben.
Measured the wheel now, it's more like 88mm in there. It's a 3.5x17" wheel. The faces where the brake discs bolt on to are 122mm apart. Could someone check, is that about right?
I'm having a scary thought now. The wheel was bought off ebay ages ago, supposedly a '99 SV650, wheel.........and i've just laid out cash to get it powdercoated!!!!!
Old 07-03-07, 08:35 PM   #4
21QUEST
21QUEST's Avatar
Thanks Ben.
B*gger mate, looks like you haven't got an SV wheel there. The SV wheel disc mounting surface distance should be about 92mm .
Ben
Old 07-03-07, 08:52 PM   #5
haggis
Ok, it's a bugger certainly - but possibly not the end of the world.
I'm now thinking it's a maybe pointy wheel, as their brake discs have flat centres ( curvies are dished), so the mounting surface must be wider apart.
I have the right bearings, a change of inner spacer could see me right. I dont have discs for it yet, so could just get pointy ones, yeah? Is the pointy caliper totally the same as a curvy one?
Any pointy owners got a bare wheel lying around, so we could compare measurements?
(beginning to tear hair from follicles!!)
Old 08-03-07, 08:16 PM   #6
haggis
BUMPITY BUMP.
Hello, is there anyone there with a pointy 650, come on I know u exist!
Whats the distance in-between the front discs at the hub please?
Old 08-03-07, 11:07 PM   #7
Quiff Wichard's Avatar
kwak's got a pointy -
and a garage.
and he's a good guy-
and as u know always cleanin his bike.. pm he .. he might nip n measure 4 u
Old 08-03-07, 11:17 PM   #8
BILLY
The same happend to me last year I bought what I thought was a SV650 front Wheel and it turned out to be a Bandit 1200 so I started a dispute with the seller and got a full refund! By the way the codes stamped on the two wheels are the same!
Old 08-03-07, 11:30 PM   #9
haggis
Thanks guys.
The thing is.... i got the wheel as a spare at least 18months ago. Can't even remember how much i paid never mind who got my cash!!!
Help ,spacer ,where From ? redbiker 954 Mini-Twins 6 16-03-08 04:13 PM
Am i missing a spacer? mario SV Talk, Tuning & Tweaking 15 28-04-06 10:04 PM
URGENT! need a spacer for inbetween back wheel and sprocket vsumouse Stuff Wanted 6 26-04-06 10:41 AM
Spacer kit to fit B12 rear wheel northwind SV Talk, Tuning & Tweaking 5 28-03-06 07:03 PM
Arrgggh! Rear wheel spacer prob. svpilot SV Talk, Tuning & Tweaking 8 21-04-05 12:34 PM
