Old 22-03-07, 01:21 PM   #1
weazelz
Default fuel tubing as replacement brake tubing?
not the pressurized bit, I hasten to add, just the bit between fluid reservoir & master cylinder. would it work or would the brake fluid do unpleassant things to it?
Old 22-03-07, 01:39 PM   #2
jamesobrady
Default Re: fuel tubing as replacement brake tubing?
Get a piece of it, leave it sitting in brake fluid for a week, then take it out and see what its like? Its very possibly the same material but I dont know.
Old 22-03-07, 01:57 PM   #3
BristolMatt
Don't know if this'll help but it looks like PTFE (if that's what it is) hoses can both be used for fuel and oil.
http://www.goodridge.co.uk/buy-goodridge-hoses.htm
Old 22-03-07, 02:32 PM   #4
Davies
I've got a set of brake lines that were taken off my bike by the previous owner when the braided lines were installed.....got no need for them so they're your if you like....just PM me.
Old 22-03-07, 02:55 PM   #5
weazelz
thanks for the offer, but I think actual brake line'd be too stiff to make the bend between the reservoir & the master cylinder
Old 23-03-07, 01:47 PM   #6
embee
embee's Avatar
Conventional brake fluid is Polyalkalene Glycol Ether according to http://www.apracing.com/motorcycle/fluid/index.htm
I can't find this (or similar description) listed in rubber resistance tables like http://www.baxterrubber.com/resistance-pg1.html
(unless it comes under the general grouping of "glycols")
but having said that, the sort of rubbers usually used for gasoline fuels generally have quite good resistance to most "non aggressive" liquids, so I'd guess you'll be OK.
Old 23-03-07, 03:24 PM   #7
SV650Racer
yes i use fuel hose on the brake master cylinder on my race bike and its fine.
Old 24-03-07, 03:38 PM   #8
petevtwin650
Just a point, I've got an HRC pipe on my rear brake. No need for a reservoir just the fluid in the pipe. Obviously it has a cap on the end to seal it. Need to keep an eye on it for a road bike, but if for racing it'd be fine. Sure you could do the same for the front brakes.
Old 24-03-07, 04:26 PM   #9
weazelz
cool, thanks
anyone want to buy a 2" piece of suzuki brake tubing for £9?
Tubing Brake Fluid Reservoir DarrenSV650S Bikes - Talk & Issues 23 22-01-09 03:30 PM
Replacement Brake Pedal lol1184 Stuff Wanted 6 02-11-07 12:19 PM
Replacement fuel light / fuel tap riktherider SV Talk, Tuning & Tweaking 7 14-05-07 06:41 PM
Mounting Scottoiler delivery tubing walnuts SV Talk, Tuning & Tweaking 14 13-06-06 09:26 AM
Scottoiler Tubing issues MarkyBoy SV Talk, Tuning & Tweaking 7 08-08-05 02:22 PM
