Old 13-04-07, 12:45 PM   #1
Taipan
Taipan's Avatar
Default Do SV carbs go out of balance a lot?
My SV seems a bit vibey and may benefit from a carb balance I suppose. Is carb balance something that needs to be checked fairly regularly?
Old 13-04-07, 04:37 PM   #2
RandyO
Default Re: Do SV carbs go out of balance a lot?
I noticed that at every recommended tuneup service interval (7500 miles)
even thought I thought my SV was running perfect, it always ran better with carb sync, new plugs & clean air filter
follow recommended suzuki sercive schedule, minor service every 3500-4000 miles, intermediate service every 7500 miles and major service(valve inspection) every 15,000 miles
and you will be rewarded with thousands and thousands of trouble free miles
Old 17-04-07, 11:15 AM   #3
Taipan
Taipan's Avatar
Thanks for that. I'll have a go at balancing it at the weekend.
Old 17-04-07, 11:17 AM   #4
Viney
I take it that you have a set of guages for such purpose?
I balance mine every service, its amazing how they do fall out so often
Old 17-04-07, 11:25 AM   #5
Grinch
I really must do mine, and learn how to do it.
Old 17-04-07, 11:26 AM   #6
Scoobs
Get some gauges - give me a call. I'll show you. I have even left a pipe on the front carb for you.
Old 17-04-07, 11:28 AM   #7
Grinch
Carbtune is that the ones?
Old 17-04-07, 11:55 AM   #8
Taipan
Taipan's Avatar
I had Carbtunes but found they lost their accuracy as the so called stainless tubes corroded and hindered operation. So I replaced them with a Twinmax which I sold after my BMW went and now I need it, just like the ABBA stand I sold. When will I learn! I digress. No i dont have any gauges at present but will maybe make up a tube one to do this.
Just looking for tips on this and found out its a right pig to hook up toteh vacuum points? Is that true?
Old 17-04-07, 11:58 AM   #9
Scoobs
They are the ones I used. Don't use ones with dials, they are pants. The mercury typr guages are a lot better IMO.
Old 17-04-07, 12:01 PM   #10
Scoobs
The rear carb is a piece of ****. The front carb is a knuckle bleeding affair. Connect up a piece of pipe to the front carb and leave it attached forever. Blank it off with a screw and some PVC / PTFE tape when not in use. Don't blank it off with anything that can be sucked up the pipe.
Balance crank yorkie_chris SV Talk, Tuning & Tweaking 25 04-12-10 01:03 PM
Balance carbs after fitting FI washers Worth it? Old Git SV Talk, Tuning & Tweaking 6 07-03-09 03:28 PM
How to Balance Carbs DarrenSV650S Bikes - Talk & Issues 20 13-01-09 06:55 PM
ne 1 in tv area that can balance carbs? sv650nutter149 Thames Valley 11 04-01-08 01:17 AM
Borrow vacum gauges to balance carbs MarkP Guildford Massive 1 05-05-06 02:34 PM
