Old 05-03-09, 09:50 PM   #1
Old Git
Old Git's Avatar
Default Balance carbs after fitting FI washers Worth it?
For no.2 son have fitted FI type washer to restrict bike, have read about this decreasing fuel consumption, making them run rich, cough, splutter, run poor etc.etc.
Am trying to think ahead, if it makes the bike run rich/bad, is it worth getting carbs re-balanced to account for the restricted airflow that the washers will have imparted?
Seems to be running OK at present, but only doing short runs & washers only been done since Tuesday.
1st real test will be on rideout Saturday, so will see how a 'hobbled' SV goes then.
Thoughts, comments, experience would be appreciated.
OG.
Old Git is offline   Reply With Quote
Old 05-03-09, 11:42 PM   #2
SVDragRacer
Default Re: Balance carbs after fitting FI washers Worth it??
I found with my restrictors in the bike still ran ok but just ran out of life after about 8000rpm, when you try to accelerate it still seemed to pick up at the same sort of rate then just started to splutter after 8000. 90mph was a out the limit before it took about an hour to gain another 5 mph.
Old 06-03-09, 01:08 PM   #3
Odin
If its spluttering or dies on idle just after the washers were fitted it, you might just need to adjust the idle speed. I needed to do that the other week.
Old 06-03-09, 01:43 PM   #4
rictus01
rictus01's Avatar
Carb balancing will have no direct effect on the washer placement at all, although good practise should see you do it after playing with the carbs for any reason, but generally if they were out to begin with then after fitting, they will still be out and likewise if they were correct, they will still be that way.
Mixture on the other hand (rich or lean) could be effected, but most seem to run fine.
Cheers Mark.
Old 06-03-09, 08:11 PM   #5
Old Git
Old Git's Avatar
Cheers Mark.
Thanks chaps, seems like sound advice, have tweeked the idle speed, seems to have solved that one.
I am a strong believer in 'if it aint broke don't fix it', so for now will leave well alone while it seems to be running OK.
Thanx
Keith
Old 07-03-09, 11:31 AM   #6
chompy
my bike seems to run ok but i also had to up the idle speed because i had a few problems with idiling when i kept dieing in idle, junctions ect. 105 can be one with the restriction altough once past 90 doesnt seem to shift for a while. and i wouldnt recomend that speed. because urmmm it was my brother that did it on my bike lol.
anyway should be ok with the restrictor.
chompy
Old 07-03-09, 03:28 PM   #7
OG.
Balancing the carbs doesn't directly affect the mixture.
Washer on carby is same effect as not opening the throttle as far.
Balance them by all means as it will do it some good as per usual, but it won't cause the engine to grenade itself if you don't.
How to Balance Carbs DarrenSV650S Bikes - Talk & Issues 20 13-01-09 06:55 PM
ne 1 in tv area that can balance carbs? sv650nutter149 Thames Valley 11 04-01-08 01:17 AM
Do SV carbs go out of balance a lot? Taipan SV Talk, Tuning & Tweaking 23 27-04-07 09:00 PM
Borrow vacum gauges to balance carbs MarkP Guildford Massive 1 05-05-06 02:34 PM
is it worth fitting a K&N???? branny SV Talk, Tuning & Tweaking 20 03-05-05 09:57 PM
