Old 15-04-07, 08:53 AM   #1
quikstu
Default Knocking sound from crankcase. SK3
Got a SV650S K3 with 13900miles on it.
Over the last few weeks I've started to hear a dull knocking sound from the crankcase. Didn't think too much of it initially but now everytime I'm on it, it's all I can hear.
Apparently when the K3 was made Suzuki got the tolerances wrong on the crank & a few have suffered bearing failure & a huge repair bill!!!!!!
Needless to say it's now booked into Cupar for 15k service & to sort the problem.
Anyone else had this???
Coincidently it's also in this months 'BIKE' magazine!
Old 15-04-07, 02:24 PM   #2
Default Re: Knocking sound from crankcase. SK3
was'nt THE KNOCK the problem with a few sv1000s k3? havent herd it on a 650
Old 15-04-07, 03:50 PM   #3
trickywoos
The Knock was a problem with a lot of the SVthou's. K3 in particular I think. They were all fixed under warranty.
If this is the same problem, ( I wasnt aware of this happening with the 650s!) check out www.suzukisv1000.com or www.sv-portal.com as there is masses of information about it!!!
Old 15-04-07, 07:08 PM   #4
suzuki didnt fix it just like that, the sv-portal site hammer'd them with letters till they finaly admited that a batch of fauty bearing was put into some engines, the 650 wasnt affected by this and the 1000 engine life was not affected either just a slight bottom end knock. these engines knocked from new so i doubt this is quikhstu's problem.
Old 15-04-07, 07:16 PM   #5
Biker Biggles
Biker Biggles's Avatar
I think I recall some of the minitwin racers saying the early pointys were prone to crankshaft failures.
Maybe SVRacer can give you the lowdown on this.
crankcase cover paint davemapp40 SV Talk, Tuning & Tweaking 8 01-02-09 10:01 PM
Amount of torque for crankcase bolts brenthilg SV Talk, Tuning & Tweaking 2 12-10-06 08:30 PM
Crankcase breather andyaikido SV Talk, Tuning & Tweaking 2 05-09-06 06:28 PM
crankcase and water pump auldyin Bikes - Talk & Issues 2 09-07-06 09:39 AM
Crankcase breather and custom airkits dubno SV Talk, Tuning & Tweaking 5 08-07-06 03:51 PM
