Old 23-04-07, 11:53 AM   #1
thedonal
Default Replacement rear axles?
Well- there's a handy thing. Went to adjust the chain yesterday and, from a combination of cheap socket set and maybe tyre fitters over tightening the rear wheel (though he did use a torque-wrench), the nut on the axle is starting to round on the exhaust side. currently I can't adjust the chain until I get my bro's better (+ bigger) sockets and undo the other nut.
So- are these available in a slightly harder metal than the OE? stainless steel would be preferable..
Cheers as ever, guys..
Old 23-04-07, 12:44 PM   #2
jambo
jambo's Avatar
Default Re: Replacement rear axles?
The metal's fne, don't use cheap sockets
Edit: That'll be possibly my least helpful post today.... Possibly....
Old 23-04-07, 01:31 PM   #3
thedonal
Er- thanks?!
Old 23-04-07, 01:55 PM   #4
John Burt
Stainless is softer that the Suzuki standard
Old 23-04-07, 02:03 PM   #5
andyaikido
Probolt probably do them.
Old 23-04-07, 03:04 PM   #6
petevtwin650
Probolt only do the axle nut, not the axle itself.
I find that doing and undoing the axle, only the nut needs to be held by a socket. The axle goes tight very quickly and can be held by hand. Same with undoing. Only use a socket on the much bigger nut. That works for me anyway. Otherwise it's ebay etc for a secondhand one.
Old 23-04-07, 04:20 PM   #7
The only place that you'll get a replacement spindle is Suzuki. If it were me I'd see if I could grind/file the hex down to the next suitable size - it's only for holding the spindle while you turn the nut.
Never use stainless for a stressed component like a wheel spindle - or be daft enough to replace suspension and brake mounting bolts with stainless 'cos it's shiny, like some people do.
Old 23-04-07, 06:03 PM   #8
thedonal
Cheers folks- looks like it was well overtight from the tyres being replaced- got the chain sorted, can undo it using the big nut for now. Sorted.
Rear Brakes, Disc and Pad Replacement - Can I? krhall Bikes - Talk & Issues 24 08-05-08 04:06 PM
Suzuki OEM top box & rear seat replacement Dysparunia SV Talk, Tuning & Tweaking 5 08-01-07 05:54 PM
Replacement Rear Shock (again!) Luckypants SV Talk, Tuning & Tweaking 21 17-09-06 11:54 PM
replacement rear shock? m6rk SV Talk, Tuning & Tweaking 15 06-04-06 12:41 PM
rear shock replacement? cassius SV Talk, Tuning & Tweaking 8 13-04-05 09:43 PM
