Old 03-05-07, 08:28 PM   #1
Mr. Bob
Default Sprocket/Chain
In my 50s and riding only four years on an '02 naked with Scorpion can, K&N air filter, 15 weight fork oil and progressive springs, fender eliminator and Sargeant seat. Why did I wait so long, I'm having a blast! I was comparing specs with the SV650/S and noticed chain was 108 links vs. my 110, and sprocket was 44 vs. my 45. At 58 testosterone levels are not as high as they used to be so I don't need to go way up on the performance scale, but if I changed out my chain and sprocket to the -S model specs, what changes might I experience, and how will the speedometer be effected?
Mr. Bob
Old 03-05-07, 08:31 PM   #2
fizzwheel
fizzwheel's Avatar
Default Re: Sprocket/Chain
It'll accelerate a litte slower and your top end speed will be a little more.
Old 03-05-07, 08:43 PM   #3
Bear
Speedo drive is off magnets on your front wheel, so speedo will still read right. Like Fizz says, you'll get better top end but sacrifice some acceleration. I've just done the opposite and dropped a tooth on the front to give more pull-away and monowheel action!
sprocket and chain Q ricky SV Talk, Tuning & Tweaking 21 01-10-09 01:52 AM
chain + sprocket SVTristan SV Talk, Tuning & Tweaking 2 08-05-09 03:01 PM
Need a new chain and sprocket... Which? sv_rider1990 SV Talk, Tuning & Tweaking 33 04-04-08 07:05 PM
520 sprocket with 525 chain? charlie13 SV Talk, Tuning & Tweaking 10 31-10-07 08:38 AM
Chain and Sprocket Ernie B SV Talk, Tuning & Tweaking 6 04-05-06 12:35 PM
