Old 30-10-07, 08:38 AM   #1
charlie13
Default 520 sprocket with 525 chain?
Hi folks,
Just wondering if anyone can advise whether it's OK to run a 520 rear sprocket with a 525 chain? I know the difference between the 520 and 525 is the width of the rollers, the 520 = 1/4" (6.35mm) and the 525 = 5/16" (7.94mm) so there's an extra 1.6mm width between the sideplates of the chain which is going to allow extra lateral movement of the chain on the sprocket. But I'm not sure whether this would be OK or not........
(There's a bit of clearance between the Renthal rear sprocket and sideplates of the 525 chain i currently have on, but i don't know whether this Renthal is a 525 or 520 rear already.)
Old 30-10-07, 10:27 AM   #2
Spanner Man
Default Re: 520 sprocket with 525 chain?
Morning all.
Definite no-no!
Cheers.
Spanner Man
Old 30-10-07, 12:11 PM   #3
charlie13
Thanks for that spanner man.
Old 30-10-07, 01:12 PM   #4
Blue_SV650S
'Pitch' is the distance between teeth isn't it??? If you overlaid a 44t 520 and a 44t 525, they wouldn't look the same ... not just one is thinner than the other ...
So no, you can't use a diff pitch chain to sprocket ...
Old 30-10-07, 01:20 PM   #5
Biker Biggles
Biker Biggles's Avatar
Thats what I thought.The 525 and 530 numbers are the distance between the pins,so the teeth on the sprocket would be the wrong distance apart.
Not a good idea.
Old 30-10-07, 02:00 PM   #6
Nah, the pitch is the first number, in eights of an inch, so they're both 5/8ths chains. Width is the second two, 525 is 5/8 pitch, 2.5/8ths width.
Still wouldn't put a 525 on a 520 chainset though, for obvious reasons, even 1/16th of an inch is quite a lot.
Old 30-10-07, 04:28 PM   #7
Biker Biggles
Thanks for unscrambling that.Ive always just made sure all the nimbers are the same without thinking what they actually mean.
Old 30-10-07, 04:45 PM   #8
Blue_SV650S
I learned something today
Old 30-10-07, 06:21 PM   #9
charlie13
If anyone want's a peep at the various sizes to compare there's a handy little table of chain dimensions on this page http://www.gizmology.net/sprockets.htm
I knew the pitch of the 525 & 520 were the same, but didn't know whether it was good or bad practice to use a mixture of 525 chain and 520 sprocket. Cheers for steering me in the right direction folks.
Old 30-10-07, 08:31 PM   #10
If it's a useless fact you need, I'm your man
sprocket and chain Q ricky SV Talk, Tuning & Tweaking 21 01-10-09 01:52 AM
chain + sprocket SVTristan SV Talk, Tuning & Tweaking 2 08-05-09 03:01 PM
Need a new chain and sprocket... Which? sv_rider1990 SV Talk, Tuning & Tweaking 33 04-04-08 07:05 PM
Sprocket/Chain Mr. Bob SV Talk, Tuning & Tweaking 2 03-05-07 08:43 PM
Chain and Sprocket Ernie B SV Talk, Tuning & Tweaking 6 04-05-06 12:35 PM
