Old 04-05-07, 07:23 PM   #1
phil24_7
Default Tyre pressures
What tyre pressures would you guy's recommend on an SV with Z6's?
Regards
Old 04-05-07, 07:31 PM   #2
Tim in Belgium
Default Re: Tyre presures
I've used 33/36 on Pirelli Diablo stradas (same thing, different badge), but no idea if it's the optimum, I can never be bothered fiddling and assessing, my ride depends so much on me that I think I'm not consistent enough in my riding skills to work out optimum pressures. Low pressure doesn't work great though!
On track I drop then 1-2 psi before the first session.
Old 04-05-07, 07:35 PM   #3
hovis
36/42 in my road attacks?
Old 04-05-07, 07:37 PM   #4
Lissa
Just Ballast
Lissa's Avatar
You get so much conflicting information about the right tyre pressures. When we fitted the Pilot Road 2's, the guy put 36 front and rear. It just didn't feel right, so I actually e mailed Michelin to ask what pressures THEY recommended. Got an e mail back too.
Dear Lissa,
Thank you for your e-mail and purchasing Michelin Tyres.
We have the following pressure recommendation -
Front at 34psi
Rear at 36 psi
There is NO requirement to increase for load/speed.
Two Wheel Department
Michelin Tyre plc
If you can't find the tyre pressure info on their web site, try e mailing them. Can't hurt!
Old 04-05-07, 08:50 PM   #5
Matt Prince
BT 020's on mine - official response was 36 front 36 rear - works well
Old 04-05-07, 08:52 PM   #6
fizzwheel
fizzwheel's Avatar
I run mine on standard pressures. 33 Front and 36 rear. Seems to work OK, I've not any complaints.
I'd start there and then tweak a few PSI here and there till you find something that works for you. Pressures are a personal thing and what I might like you might hate.
Old 04-05-07, 08:57 PM   #7
650sx
in haynes manual it say 33 front and 36 rear dont know if these are for the standard tyres when new, but i use them pressures in bridgestone batlax and it seems fine to me....
Old 04-05-07, 09:18 PM   #8
thebluelion
When i got my pirelli Diablo Stradas fitted guy put 33 front 37 rear, feels ok to me
Old 04-05-07, 09:23 PM   #9
Zico
Remember to take the pressure when tyres are cold!
Old 04-05-07, 11:54 PM   #10
SV650Guern
i always put in 1 or 2 psi over the recommendation helps on the twisty bits and trust me we have a lot of twisty bits lol!
Tyre pressures AndyBrad SV Talk, Tuning & Tweaking 33 05-09-08 09:10 PM
Road Tyre Pressures and tyre problems G Bikes - Talk & Issues 14 05-06-08 03:29 PM
Tyre Pressures redbiker 954 Mini-Twins 5 21-02-08 10:25 PM
Tyre pressures mxm35948 SV Talk, Tuning & Tweaking 13 10-09-07 04:18 PM
Tyre pressures - help! benny SV Talk, Tuning & Tweaking 3 03-04-05 08:43 PM
