Old 11-05-07, 05:42 PM   #1
Steve_God
Default Opinion on Radiator!
Hi all,
Went on a trackday, had an offy, and the only potentially serious damage was to the radiator. (The Fairing bracket attached seems to transfer the weight to it)
See here:
Now... it runs fine, no temperature issues, however not sure whether how far it has moved back would have damaged anything else, and thought I'd see if anyone has had anything similar happen to them - or know more technical knowledge about what exactly it could've moved into!
Old 11-05-07, 06:24 PM   #2
Bluepete
Bluepete's Avatar
Default Re: Opinion on Radiator!
No ideas about the rad, but good to see the OEM fairing mounts which are also used to mount the Suzuki crash bungs were up to their usual high standard and folded at the first opportunity!
(still bitter about the damage mine caused when they folded!)
Old 11-05-07, 06:45 PM   #3
rictus01
rictus01's Avatar
If you run the bike up to temp and the fan cuts in and works, then you'll be fine as it is, the fan and wiring is all you'll have damaged behind there.
Cheers Mark.
Old 11-05-07, 09:08 PM   #4
Nekkid
Cheers Mark.
Yup, just so.
If it works, just keep on truckin'.
Old 11-05-07, 10:33 PM   #5
Stu
Trinity
Stu's Avatar
You're rad doesn't look as bad as mine. But your rad guard looks worse (do you want a replacement?).
The only issue I had was the Rad pushed the radiator hoe to foul the throttle so it didn't return and I had cruise control. But has been fine for a long time now after I pushed it back out of the way.
Old 13-05-07, 03:55 AM   #6
kcowgergmm
i bent mine in my wreck but it still works with no leaks so i figured it was good enough
Old 13-05-07, 04:57 PM   #7
Brucey
I would check that the fan can still spin as others gave suggested mine has been bent worse than yours and has covered several thousand miles without any problems.
Old 14-05-07, 12:05 AM   #8
kcowgergmm
if it starts leaking just but some bubble gum in it that should work
.org Opinion Neeja Idle Banter 29 13-08-08 01:27 PM
What is the opinion of MCE timwilky Bikes - Talk & Issues 6 17-10-07 07:31 PM
Your opinion please svrash SV Talk, Tuning & Tweaking 9 29-06-06 04:39 PM
Just my opinion Dicky Ticker The Essex Lounge 3 09-04-06 09:50 AM
