Old 15-05-07, 09:21 AM   #1
sami_g
Default Can't use my SV in the wet.
Hello,
I have an sv650 k1, when i take the bike out in the wet the spray form the front wheel gets into the front spark plug, and the bike then runs like a 50cc, i have tried new spark plug leeds, fender extender, wd40, so now im out of ideas, CAN SOMEONE PLEASE HELP ME ON THIS ONE?????
Old 15-05-07, 09:30 AM   #2
Baph
Default Re: can use my sv in the wet, HELP
If a fender extender hasn't sorted it, you'll need to dry it out again, then stick the plug back in & cover in silicon grease.
Old 15-05-07, 09:33 AM   #3
petevtwin650
Could be a problem elsewhere. Check the connections to the coils. Maybe water is getting in there. Crimp em up tight.
Old 15-05-07, 09:36 AM   #4
SV650Racer
You need to make sure the drain hole on the side of the engine is cleaned out and free of dirt. This then stops the plug hole from filling with water.
Old 15-05-07, 09:38 AM   #5
the_runt69
If it was like mine the front lead and plug were fuchsaid, get a new plug, plug holder and a length of HT lead and change the lot. it wont tell which bit was wrong but at least it will work
h
Old 15-05-07, 09:46 AM   #6
sami_g
I have tried that and it still gets wet, ant other ideas please ????
Old 15-05-07, 09:49 AM   #7
petevtwin650
3 more different suggestions above. Did you miss them Sami?
Are you sure the plug gets wet or just assume it cos it's running rough?
Old 15-05-07, 09:49 AM   #8
sami_g
tried most of those and still gettin wet, the water id gettin in to the front cilinder and givin me loads of grieff
Old 15-05-07, 09:50 AM   #9
the_runt69
Have you looked inside the plug lead, if thats going hom,e on the contact, Take the plugs out and see if theres a spark and then youll see if the waters shagged the leads
Old 15-05-07, 09:52 AM   #10
fizzwheel
fizzwheel's Avatar
When you've refitted the plug cap on the front plug have you made sure that the rubber grommet is sat down properly in the grove, if its not fitted properly it'll let the wet back in.
