Old 23-05-07, 02:20 PM   #1
aarond
Default removing fuse retainer
Hi i was wondering if someone could tell me how to remove the fuse retainer (the metal bit that holds the fuse in the plastic box) the fuse retainer i am trying to remove is the igntion feed, orange wire, on a 99 curvy thanks
Old 24-05-07, 11:51 AM   #2
Default Re: removing fuse retainer
Do you meant the contacts in the fusebox?
Old 24-05-07, 11:52 AM   #3
John Burt
If you look at the metal bit from the rear of the fuse box, where the wires go in, you should be able to see a small tag that prevents the clip from being pulled out. It's not a seperate clip but part of the fuse holder if you can depress it you should be able to pul the fuse holder out. BE GENTLE
Old 24-05-07, 12:08 PM   #4
aarond
Yep thanks
Old 24-05-07, 12:11 PM   #5
Then, like John Burt says I've got a ground down nail that works really well for this stuff.
Old 24-05-07, 12:32 PM   #6
aarond
thanks
Old 24-05-07, 01:02 PM   #7
John Burt
Finger or Toe
fuse keeps blowing bobm SV Talk, Tuning & Tweaking 5 23-10-08 07:57 AM
Fuse on K1 ginettav8 SV Talk, Tuning & Tweaking 1 04-06-08 11:32 AM
Ignition fuse redeye321 SV Talk, Tuning & Tweaking 1 10-01-06 11:09 AM
Where to put the fuse box? andyaikido SV Talk, Tuning & Tweaking 1 22-11-05 10:36 PM
Rear brake pad retainer TSM SV Talk, Tuning & Tweaking 8 21-03-05 01:05 PM
