Old 28-05-07, 05:38 PM   #1
Default question for car lovers
how do i find out which model number my passat 1.9 tdi is and is it the pd engine version or not? its on a 04 plate?
Old 28-05-07, 05:58 PM   #2
Dicky Ticker
Default Re: question for car lovers
Ask any VW Agent. They will know by the VIN No.
Old 28-05-07, 05:59 PM   #3
thought it might be on the log book but i cant see it anywhere?
Old 28-05-07, 06:03 PM   #4
fizzwheel
fizzwheel's Avatar
I think you can tell by how many red letters there are in the TDI on the boot lid.... but that might be the BHP rating of the engine.
Old 28-05-07, 06:04 PM   #5
gettin2dizzy
give another passat a drag race
Old 28-05-07, 06:12 PM   #6
its the red I model which is 100 bhp but the model is either 5b or 5.5b ? i wouldnt take much notice of the TDI badge most tdi's have that pluggin chip off ebay which pushes up the bhp anyhow.
Old 28-05-07, 07:10 PM   #7
quikstu
I thought all TDi's from Mk 4 onwards were PD, being the type of fuel pump; 'Pumpe Deuse'.
Or summin like that spelling.
I have a Golf Mk 4 TDi 130bhp & it says PD on the sticker in the inside of the log book.
HTH
Old 28-05-07, 07:40 PM   #8
Treacle
Treacle's Avatar
The best way to check is to find the engine code. I will be three letters normaly starting with an A**. You can ether find it on the cambelt cover in the engine bay or on the fectory spec sticker which should be under the carpet in the boot. Give me a shout if you need the engine spec.
HTH
Matt
"If Carlsberg made ginger bloke's............................. "
Treacle is offline   Reply With Quote
Old 28-05-07, 07:51 PM   #9
TSM
The Sick Man
TSM's Avatar
VW in the boot, usualy also write the PS of the engine or KW.
Dont believe the Red letters in the TDi as some peeps found changes and iregulatiries.
Also give a try over at www.uk-mkivs.net
Old 29-05-07, 03:22 PM   #10
600+
the PD engine is smaller, quieter and a square as well
One for the dog lovers on here Paws Idle Banter 25 07-02-09 02:10 AM
For cat lovers... Cazza Idle Banter 2 14-12-07 07:28 AM
dog lovers can you help? socommk23 Idle Banter 5 16-01-07 08:16 PM
For cat lovers (not) Essex of Essex Idle Banter 87 14-11-06 04:10 PM
One for the cat lovers among you... El Saxo Idle Banter 35 21-10-06 09:25 AM
