Old 04-07-07, 07:16 PM   #1
FishyMug
Default Need advice on front suspension
I know this has prob been covered many times, but I cannot believe how easy the forks bottom out over an uneven surface, what is the quickest/easiest/cheapest way to improve this without upsetting the ride quality or handling too much?
Old 04-07-07, 07:21 PM   #2
neio79
Default Re: Need advice on front suspension
new progressive fork springs and thicker oil, hyperpro do a kit and hein gerike sell it aparantly.
I will be doinfg said mod in the winter ( well that could be now to be honest) as well as changing the rear shock spring and raising the back end via dog bone change.
Old 04-07-07, 07:24 PM   #3
Luckypants
Luckypants's Avatar
Your right, it's been covered loads of times. Try using the search function, you will find loads of information on the subject. If you still have some questions, they you can ask and get more specific answers.
Try things like 'fork springs' ' fork oil' etc
Old 04-07-07, 11:25 PM   #4
21QUEST
21QUEST's Avatar
Not being rude but how are you sure that's what is happening?
I have a naked SV with standard spring and more or less standard viscosity and it definitely doesn't bottom out(that easily) as plenty of folks seem to find.
Thicker oil is not necessarily better especially with standard springs. The Hyperpro kit comes with oil included but who knows what the actual viscosity is. They do tend to run some funny air gaps though(I think).
Ben
Nemo me impune lacessit.
Old 05-07-07, 06:15 AM   #5
SoulKiss
SoulKiss's Avatar
Ben
15W Oil and a 140mm Air Gap (Mr Suzuki's standard is 96mm)
They work tho.
One point tho, they dont HAVE to be Hyperpro Progressives, its what I got but only really because they do a front and rear spring set,and they were fairly easy to get.
Plenty of manufacturers of fork springs out there.
I am very happy with my Hyperpro's, but I havent tried the others.
Old 05-07-07, 06:55 AM   #6
danf1234
I have just done hyperpro progressive springs on the front, Nitron rear shcok, and 30mm Janck up Bandit mania dog bones.
It improves the ride no end. Also I am 5ft 11" and the bike is now the perfect height for me.
Well worth the outlay,
Old 05-07-07, 07:50 AM   #7
ejohnh
Hagon progressive springs and 15 W oil - kit = £62.50 delivered to mainland UK
Old 05-07-07, 08:14 AM   #8
MiniMatt
'Tis a good point. When I was racing (only ratty old MZs but people get very carried away in that class to eek out every little advantage) I used to set suspension up for every track. The trick was to tie a ziptie (not too tight mind) to one of the fork legs, go out and do a few laps, come back and find out how much travel the forks were getting.
You always need to allow extra room for potholes and general freakiness on a road of course, on a track it's a known environment and you can tailor your springs to the travel needed.
Old 05-07-07, 09:20 AM   #9
SV650Racer
Matt who much do you weigh?. What sort of riding are you doing?. Are you jabbing on the brakes making the front feel like its bottoming out?.
There are a few factors to consider before choosing the correct route as far as springs, oil weight and air gap go.
Old 05-07-07, 09:28 AM   #10
Exactly... Believe it or not there's some freakos on this site who'er actually light enough for the OE springs Though the "average" SV rider does start to benefit from stiffer ones. I bet you a shiny pound that your forks aren't bottoming out though, unless you're mahoosive.
Suspension advice required - ZX6R-B1H. andyb Bikes - Talk & Issues 19 31-01-09 08:22 PM
Suspension advice pointy. ScottishRawker SV Talk, Tuning & Tweaking 10 24-04-08 12:21 AM
Suspension overhaul Advice welcome Jackie_Black SV Talk, Tuning & Tweaking 0 16-03-08 09:20 PM
OK, Front Suspension adjustment/ advice ccurts SV Talk, Tuning & Tweaking 35 02-05-07 07:30 AM
Help - need advice on suspension settings monkfish SV Talk, Tuning & Tweaking 2 12-11-05 07:42 PM
