Old 24-07-07, 09:33 AM   #1
dmracing
Default What is wrong with my chain?!
Poxy thing has only been on the bike for 4,000 miles and I think its on its way out. I'm having to adjust the chain every day (100 miles) as it keeps stretching.
Weirdest thing is that today its not as loose as it has been. But its still clonking like its going to snap off.
Any ideas why its doing this?
Old 24-07-07, 09:41 AM   #2
rictus01
rictus01's Avatar
Default Re: What is wrong with my chain?!
Once fitted from new you could expect a little adjustment to be needed as it settles down, but shouldn't need regular ones after that until it's on it's way out.
Either you've let it dry out and the "o" rings have given up.
didn't buy an O-ring chain in the first place
Or of course haven't lubed it at all.
As you say you've only done 4,000 mile on it then it's only a month or two old ? if none of the above is applicable then send it back as it's faulty.
Cheers Mark.
Old 24-07-07, 04:01 PM   #3
Spanner Man
Afternoon all.
Depends on what make & grade it was, & as pointed out how it's been looked after. Some of the cheaper chains on the market could wear out in this mileage. It would be best to replace it along with the sprockets to be on the safe side.
Spanner Man
Old 24-07-07, 06:32 PM   #4
mister c
mister c's Avatar
My son (the cheapskate) fitted a cheap non o ring chain on his CBF600, it lasted 1000 miles before it snapped on the M6 at 80MPH.
The original Honda chain gave him 16000 miles with no problems. He's now splashed out on a decent O ring chain & sprocket kit and has had no problems since.
Did you fit the new chain onto old sprockets? That will make the chain deteriorate faster than normal.
Old 24-07-07, 09:17 PM   #5
dmracing
I was contemplating putting and afam chain on but decided to let my Suzuki dealer fit an official Suzuki one along with new sprockets when the service came up. They were the same price and the original last 16,000 miles before it gave up so I thought why not.
I look after my chain too! I do 500 miles a week and I make sure it gets a coat of Wurth Chain Lube atleast once a week.
Old 24-07-07, 10:15 PM   #6
buckstone
Mine did exactly the same - went from just over half way along the adjusters to off the end in the space of the Assen MotoGP weekend (although it did last 9k).
I got a 530 inssead of the original 525. Heavier duty but no more expensive - might be worth considering .............
buckstone is offline   Reply With Quote
Old 24-07-07, 11:22 PM   #7
tigersaw
tigersaw's Avatar
Its clonking as the wheel rotates? It does this on a paddock stand? Is the wheel correctly aligned? When adjusted correctly can you pull it away from the sprocket at mid position? (well stretched if so)
Old 24-07-07, 11:41 PM   #8
rictus01
rictus01's Avatar
Spray loob should be applied every 200 miles or so, basically to keep the "o" rings moist.
the last SV chain I had lasted 54,600 miles although that did have a scottoiler fitted and was never allowed to run dry.
Cheers Mark.
Old 25-07-07, 02:12 AM   #9
melody
Cheers Mark.
How 'moist' should the chain be?? All this talk of snapping chains is getting me worried.Mine was last oiled about 500 miles ago (just before AR07) and it still looks pretty greasy to me. Should I be spraying on some loob weekly??
Melody
Old 25-07-07, 07:30 AM   #10
Dan
54,600 miles... scottoiler
'Nuff said.
Chain / Sprocket Kit wrong parts delivered, do I keep? lazymanc SV Talk, Tuning & Tweaking 26 06-05-09 09:07 PM
So what actually goes wrong with the cam chain tensors? svrash SV Talk, Tuning & Tweaking 10 25-06-06 12:19 AM
When wearing high heels was wrong, so wrong... Razor Idle Banter 6 03-06-06 08:51 AM
Will stiff chain link cause chain noise dclifford SV Talk, Tuning & Tweaking 8 16-08-05 11:56 AM
Wrong Construction wrong colour . amarko5 Bodywork 12 30-10-04 03:23 PM
