My top tip today is... lift up the tank and rip the foam off the underside.
I had a mare for nearly a week last year when this came loose and I couldn't understand why the bike wouldn't go over about 60, the mad thing being that it misbehaved the same every time. The foam was falling onto the air intake and blocking it off. Stuck it back on, sorted, then the other day had to make a quick getaway from a numpty in a Beemer, and once into ban territory it was really struggling. Checked the carb balance again (just done anyway, and was still fine, no surprise), and noticed the foam had come loose at the front edge, so I think it was flapping down in the wind. Yanked it all off as far back as the back of the intake. And now, well, let's just say it was back to normal! Say no to the foam! Free yourself! Cast off the shackles of induction noise abatement! A first class ticket to Dottingham! |
good man! finally got rid of it!. i had a mission trying to get the stuff off. just make sure there isnt any bits left there either they can be sucked in.
i did it too
as it lets more are in............... so they say? now you need tank raisers |
It's a total sod to get off isn't it
I've just said this somewhere else so might get told off by admin (sorry). I just got rid of the foam on mine, and discovered that Holts Damp Start dissolves the adhesive big time!
Lift the tank, stuff a rag in the air intake to keep the crap out. Spray on loads of damp start, let it soak. Then use an old bank card to scrape it all off. Would recommend gloves though because it goes a bit sticky. |
this thread leads me nicly to a few questions (espicly as my sv should be returned to me this week) what is the reason for the foam in the first place? and what advantages are there to lifting the tank on spacers?
more air into air box
thus more induction noise (if u notice) |
same happened to me about a month after I got the bike. but mine would run til about 6000rpm and then just cut out. was a real B&$@h to find the problem
#9 | |
Factory Pro did a load of dyno tests, apparently, and came up with 17mm as the ideal spacer size.
#10 | |
Seat foam/cover | Flamin_Squirrel | Bikes - Talk & Issues | 1 | 14-10-07 05:20 PM |
Grr.. tank bras.. stupid powersellers | veraliar | SV Talk, Tuning & Tweaking | 16 | 22-07-07 01:45 PM |
removing airbox foam | hovis | SV Talk, Tuning & Tweaking | 27 | 08-01-07 09:36 PM |
foam under tank | 01 sv650s | SV Talk, Tuning & Tweaking | 9 | 02-11-06 08:22 PM |
inserted new foam in my seat myself.! | Quiff Wichard | Photos | 27 | 14-05-06 09:25 PM |
