Old 11-09-07, 07:53 PM   #1
loneranger
Default gear problems
having trouble getting me sv650 into neutral sometimes especially sitting at lights,any ideas,cheers
Old 11-09-07, 07:56 PM   #2
Alpinestarhero
Default Re: gear problems
Check chain, check clutch cable adjustment. Most likley culprit is the clutch. Try rocking the bike about a bit too
Matt
Old 12-09-07, 12:02 AM   #3
rictus01
rictus01's Avatar
Ha ha, shake the bike? where did that come from.
But in all probablility it's the clutch adjustment, try the cam adjuster under the front sprocket cover, but also the normal, shift shaft, oil level issues.
Cheers Mark.
Old 12-09-07, 06:33 AM   #4
Spanner Man
Morning all.
As suggested, the clutch adjustment is most likely to be the culprit. But also make sure the gear lever is pivoting smoothly.
Cheers.
Spanner Man
Old 12-09-07, 07:37 AM   #5
fizzwheel
fizzwheel's Avatar
What the others said, but check the oil level, I've found in the past that if the bikes got to much oil in it, it can be a b*gger to get into neutral.
Old 12-09-07, 11:40 AM   #6
neio79
Agreed, mine done it for some random reason when out on my bikesafe this weekend gone, and looking i had just over the full on my oil spyglass.
but a few revs before getting it in N seems to do the job.
Old 12-09-07, 07:57 PM   #7
loneranger
thanks lads,the clutch has been adjusted to maximum 'will new clutch sort it out?
Old 13-09-07, 07:52 AM   #8
rictus01
rictus01's Avatar
so all three adjustment points are at maximum then, or do you mean you've screwed out the handlebar one ?
Gear changing problems vardypeeps SV Talk, Tuning & Tweaking 2 02-04-09 01:05 PM
gear problems riktherider SV Talk, Tuning & Tweaking 7 03-07-06 01:46 AM
Gear Selection Problems Iansv SV Talk, Tuning & Tweaking 14 12-01-06 03:14 PM
Gear change problems rubbermonkey SV Talk, Tuning & Tweaking 1 25-12-05 04:32 PM
Gear problems Ceri JC SV Talk, Tuning & Tweaking 3 25-04-05 08:17 AM
