Old 18-09-07, 07:21 PM   #1
monkey
Default Cleanliness inspection from Kwak required!
Here are some (rather bad I'm afraid) pics I've taken with the progress in cleaning my bike up for sale.
Points out of ten please Kwak for the spring and the swingarm bearing in mind I've never cleaned them in four and a half years!
Thanks Kwak.
Old 18-09-07, 07:29 PM   #2
Davie
Default Re: Cleanliness inspection from Kwak required!
just look at that downpipe
Old 18-09-07, 07:29 PM   #3
Razor
A purple SV?
Old 18-09-07, 07:37 PM   #4
monkey
Downpipe noted. I'll do that in Thursday along with fitting a new clamp. You can see the rot on the one there!
No it's not purple, it was taken in bad light but someone left the white balance on flourescent so I had to correct the colour a bit before I posted.
What about the swing arm and spring though? Eh? Eh?
Old 18-09-07, 08:02 PM   #5
Brian
I'll give you 8 out of ten for not cleaning your chain and also not polishing your dogbones (which count as half a point each).
A clean chain allways gives the impression that you've really put your heart and soul into keeping your bike in tip-top form throughout it's life and is the icing on the cake for a clean bike (it's a messy job though).
I was going to deduct another point for your downpipes (yes both of them) but I see you're gonna sort that out.
Polish EVERYWHERE, even the bits people won't see.
As far as your shock and swingarm goes, i'll give you 9/10, for the simple reason of "the likes of Kwak and myself are never satisfied"
Btw, you missed a bit on your oil cooler
Old 18-09-07, 08:11 PM   #6
monkey
Cheers Brian. What's the best way to clean a chain? I have chain cleaner spray but never done it! I've had it done though. Do I just turn the rear wheel and spray the ***t out of the chain catching any mess that falls off? I've got some rust on my lower triple clamp (I think-holds the forks together!). How do I go about getting rid of that?
Old 18-09-07, 08:28 PM   #7
hovis
less cleaning.............. more riding
Old 18-09-07, 08:46 PM   #8
if it's been cleaned as little as you say then WELL DONE! she's come up a treat, i find car engine oil cleans chains up well but it does make load of fling for a few 100 miles, i also use wd40 on a rag, have also been known to clean the links with autosol but when you get to this stage that both me and cuz have got to then you DO! have a problem.
Old 18-09-07, 08:58 PM   #9
monkey
I'm selling it numb nuts! He he he. Get with the program Hovis!
Old 18-09-07, 08:58 PM   #10
monkey
What about the rust?
Timing inspection plug thing - how to get new one Durbs SV Talk, Tuning & Tweaking 7 12-09-08 07:31 AM
Arai helmet inspection service? r1ck Helmets 19 06-06-08 09:07 AM
me and kwak cuz Idle Banter 19 17-03-08 12:35 PM
Water Temp indicator light inspection rcmark Bikes - Talk & Issues 1 13-08-05 11:36 AM
