Old 01-10-07, 11:32 AM   #1
Ceri JC
Default Correct order of doing the following jobs
I need to do the TPS adjustment, Throttle body balancing and Valve clearences. I was wondering which order I should do them in as I know the TPS can be affected by the throttle body balancing. Obviously the first two won't actually effect the results of the third, but I was wondering if after altering the shims (if necessary) it would affect the TPS and/or throttle body balance?
I think I've finally got all the tools needed, just wanted to see what the right order was before I get my hands dirty. Thanks in advance.
Old 01-10-07, 11:53 AM   #2
Spanner Man
Default Re: Correct order of doing the following jobs
Morning all.
Valve shims first, TPS adjustment second, & balancing third.
Incorrect valve clearances can indeed cause the synchronization to wander.
Cheers.
Spanner Man
Old 01-10-07, 11:59 AM   #3
Ceri JC
Thank you, Sir. I ended up going for the carbtune you recommened (2 cyclinder, "carbtune pro").
Old 01-10-07, 12:06 PM   #4
Biker_Billy
Where did you get it from Ceri? Direct from Morgan? - I heard that they are having supply issues? Sorry to derail your thread...
Old 01-10-07, 12:17 PM   #5
Ceri JC
Busters. They had them in stock and, oddly enough, it worked out a couple of quid cheaper than buying direct.
Old 01-10-07, 12:18 PM   #6
Stu
Trinity
Stu's Avatar
Originally Posted by Spanner Man View Post
Morning all.
Cheers.
Like Ceri, I too thought the TPS was affected by balancing the throttle bodies. I stand corrected.
Old 01-10-07, 12:20 PM   #7
Stu
Trinity
Stu's Avatar
Oh and how much damage are you doing if all 3 are seriously out?
Old 01-10-07, 01:17 PM   #8
jambo
jambo's Avatar
As a major service should include Valve clearance check and carb sync anyway, it's not a lot more work to check the TPS while you're in there...
Old 01-10-07, 01:26 PM   #9
Spanner Man
Afternoon all.
I always find that as balance has the greatest effect on how an engine runs, it's best to it do last. Although in practise you could do the TPS adjustment last, as it has no effect on the balance of the throttle bodies.
Stu, valve clearances are the main thing that can damage your engine if they're seriously out of tolerance. Poor balance & TPS adjustment though not ideal, tend to make your engine run lumpy, as opposed to seriously damaging anything. I'd still get it sorted though.
Cheers.
Spanner Man
Old 01-10-07, 01:46 PM   #10
Stu
Trinity
Stu's Avatar
Afternoon all.
Cheers.
I think that's what I've got at the mo' seriously lumpy vibration through the footpegs & viscous throttle response. Hope the clearences are OK - any telltale signs for them?
is it correct oil? viva_unix SV Talk, Tuning & Tweaking 10 23-12-07 05:41 PM
Is my licence correct??? neilhatch Bikes - Talk & Issues 4 25-03-07 09:08 PM
PSI gauges which one is correct ? SpankyHam Bikes - Talk & Issues 13 18-07-06 06:58 PM
The correct way to filter... caines Bikes - Talk & Issues 15 30-11-05 09:44 PM
