Closed Thread
Old 31-10-07, 07:37 PM   #1
svdemon
Default "Trick" Gear Lever Pointy
As title, knurled aluminium instead of the standard rubber covered job. I'll get a pic up asap.
AFAIK this will fit K3 pointys and maybe curvy's, can anyone confirm?
£15 + postage.
Old 01-11-07, 12:24 PM   #2
Bayside GTR
Default Re: "Trick" Gear Lever Pointy
I might be interested, If its not already gone. Can you post the pic.
Old 01-11-07, 12:41 PM   #3
Bear
Be aware that the gear lever for the k3 is different from later models: basically the K3 pivots from the footrest, whereas later bikes have a separate pivot point. What year is it for Demon?
Old 03-11-07, 11:40 AM   #4
svdemon
Thats a good point Bear, i have never fitted it so i don't know for sure. I reckon its a K3?
Old 03-11-07, 03:09 PM   #5
Bear
It is indeed. I have one as well, which doesn't fit my k5. You can fit it to a later model, but you have to have the whole footpeg assembly from a K3 to do it, including the longer gear linkage rod.
Bit of a pain to be honest!
Old 03-11-07, 03:10 PM   #6
Bear
I believe (although not sure) that it will fit earlier models as well...
Old 04-11-07, 12:15 PM   #7
svdemon
SOLD, can a moderator lock or delete this thread please.
Old 04-11-07, 02:12 PM   #8
Jester666
Done!
Closed Thread
Wanted: SV650 Front Wheel (2004,"pointy",Injected) williamturner1 Stuff Wanted 6 08-02-09 11:01 PM
Using "Pointy" Tensioners in a "Curvy"? dtr125 SV Talk, Tuning & Tweaking 25 05-02-09 05:42 PM
Indicator housing/shell & "gear lever"? ooger Stuff Wanted 14 13-11-07 02:21 PM
Curvey "N" clutch lever mount Jase22 Stuff Wanted 1 02-09-07 09:18 AM
