Old 06-11-07, 07:52 PM   #1
Kate Moss
Default how mad do you think he will be???
phil is away on a course tonight. i wanted to do a nice thing while he was away but it seems to have gone a little umm wrong (ish)
I bought some paint on the way home and i've started to decorate the spare room, i tried my best but it looks a bit crap - a bit splodgy and patchy and now i may have just caused him more work eeeeeek. i only did one and a bit walls because i didn't want to ruin the whole room. d'ya think he'l be mad?
Old 06-11-07, 07:53 PM   #2
hovis
Default Re: how mad do you think he will be???
typical
never atempt a mans job
you should stick to dusting
Old 06-11-07, 07:55 PM   #3
Jdubya
*hint*
Put the brush away and get a roller...
Old 06-11-07, 07:55 PM   #4
i wont allow my wife with a paint brush, the last time she glossed a door that thick that it took hours to sand the runn's out of the paintwork.
Old 06-11-07, 07:56 PM   #5
Wideboy
Evel Knievel
Wideboy's Avatar
move some furniture in front of it, no one will know
05 DRZ400E
RIP hovis
Old 06-11-07, 07:58 PM   #6
hang a poster up.
Old 06-11-07, 08:04 PM   #7
Bear
Slaughter a cow and leave the entrails strewn all over the house. Then he won't notice the walls so much.
HTH
Old 06-11-07, 08:08 PM   #8
Kate Moss
i did use a roller. the wall i ruined i the one where a 3 door wardrobe will be going so it doesn't matter to much right??
i only wanted to do nice thing - you're right i'll stick to the cleaing!
Old 06-11-07, 08:18 PM   #9
fizzwheel
fizzwheel's Avatar
Sounds like it needs a second coat, what surface did you paint over existing paint of wallpaper ?
If its paint it'll need sanding lightly and then another coat putting over it I expect, but let it dry before you do so emulsion dries pretty quickly so you might get time to give it another coat this evening.
If it were me I wouldnt be mad...
Old 06-11-07, 08:19 PM   #10
Luckypants
Luckypants's Avatar
Pah! have more confidence in yourself woman! If you are changing the colour quite dramatically then it will take at least two and probably three coats. Go back with your roller and go over it again, bet it looks much better after two coats.
