Old 08-11-07, 12:38 PM   #1
NorfolkFarmHand
Default Fitting Braided hoses
Hi
I recently bought some braided hoses from ebay,
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWN:IT&ih=006
The rear one fits like a glove exactly the same length as the rubber one. But the front hoses are about 6 inches longer that the older rubber ones.
Anyone else find the same problem? Do i stop moaning and tuck the extra hose inside the body. Another biker friend of bike said they might even be ment to be tucked inside the forks but that seems wrong.
Thanks
Chris
Old 08-11-07, 12:59 PM   #2
Default Re: Fitting Braided hoses
As you mention the body I presume you have an S model not the nekkid one.
Its a common mistake if you have an SV650S and buy hoses for an SV650, the lower clip on bars of the "S" model leave a lot of slack in the hoses if you get the ones meant for a nekkid.
They'll still work fine so long as you can route the hoses so they aren't snagging, chaffing, kinking or anything else, remembering that some slack is needed to allow for fork compression/extension, and any movement when turning if you're routing hoses inside the fairing.
As for tucked inside the forks
Old 08-11-07, 01:15 PM   #3
Luckypants
Luckypants's Avatar
He's right you know. Not bad for a young 'un.
BTW Croeso!
Luckypants is online now   Reply With Quote
Old 08-11-07, 01:20 PM   #4
tomjones2
If you ask goodridge nicley they might shorten them for you. My Earls rear brake line was way to long on the SV and as they are a local company to me I poped in and they shortened them there and then.
Old 08-11-07, 03:32 PM   #5
Mike2165
Is it right that you only get the rear hose from the pedal to the caliper? Isn't there a conflict, for want of a better word, with the tube from the pedal to the cylinder being rubber still? Or am I being thick...again!
Old 08-11-07, 04:35 PM   #6
NorfolkFarmHand
Yeah both hoses only go from the piston to the calipers, no point putting braided hoses between reservor and piston.
Thanks to all your replies gonna go have a play as soon as possible (after i fix my sisters car that is!)
Chris
Old 08-11-07, 06:07 PM   #7
The hose from the reservoir to the master cylinder isn't a pressurised hose, no need for expensive replacements - unless you require bling of course
Old 09-11-07, 10:09 AM   #8
Mike2165
Cool ta SS thats answered a question
Old 09-11-07, 10:36 AM   #9
Luckypants
Luckypants's Avatar
Ahem!
Old 09-11-07, 12:49 PM   #10
NorfolkFarmHand
Hi guys, turns out the hoses are race length. So they are fitted direct from the piston rather than going via a joining pipe. Which does explain why there were less bolts than i was taking off. So should be no problems and more importantly no slack now!
Chris
Braided hoses Alpinestarhero SV Talk, Tuning & Tweaking 37 02-11-07 11:38 PM
fitting braided hoses loneranger SV Talk, Tuning & Tweaking 8 26-10-07 04:30 PM
braided hoses hovis SV Talk, Tuning & Tweaking 9 15-11-06 07:03 PM
Braided hoses.. anything I should look out for ?? valleyboy Bikes - Talk & Issues 15 18-12-05 03:23 PM
Fitting Braided Hoses to a K4 SV650S wezza SV Talk, Tuning & Tweaking 14 20-04-05 08:40 PM
