Old 09-10-09, 07:28 PM   #121
Default Re: rear shock change
That's about your lot really unless you want to spend USD760 on a penske.
GSXR750SRAD is good length, but way too soft for 15stone.
Old 09-10-09, 07:47 PM   #122
Rob969
would it be a worthwhile improvement fitting the zx10r shock, i'm looking for things to do over winter plan on giving it a good service, braided lines, probably change the front springs and oil and thought that this would be an easyish job to improve the bike without spending a fortune.
Old 10-10-09, 08:51 AM   #123
BlackMage23
Hello,
I stuck a 2004 ZX10R shock on my curvy. It went on with no problems and I am very happy with the result. A real bargain at just £40, you can't really do much better for the price.
Old 10-10-09, 10:01 AM   #124
Rob969
Originally Posted by BlackMage23 View Post
Hello,
Hi, does it feel much stiffer looking at the numbers its not a huge difference. Also how good are they for adjustment? did you have to change/modify anything else or is it pretty much just a straight swap.
thanks
Old 10-10-09, 10:04 AM   #125
BlackMage23
It does feel better. the stock one is so cheap that anything is a upgrade really.
not played around with adjustments really as it felt good after putting it on.
No mods needed, you can use the same bolt at the top as the SV one, but you do need to get a new lower bolt. Can't remember the size, got the info from searching on here.
Old 10-10-09, 10:45 AM   #126
Rob969
cheers for the info think i'll have to look into getting one.
Old 11-10-09, 05:37 PM   #127
barwel1992
got the shock in and rode it to the gfs house what a improvment the bike dosent dive at the back under heavy eceloration just a great upgrade that cost me £20 lol thats including £150 worth of tools and stuf as me and my dad went shoping for some up to date stuf
Old 13-10-09, 08:28 PM   #128
pms jones
Just got my new battery today only 105mm tall.So the seat fits with the foam still on after cutting the battery box to fit the gsxr 1000 shock.looks just like the standard bike under the seat again.Shock has a good feel to it now just got to spend some time with the settings now.
Old 13-10-09, 09:37 PM   #129
barwel1992
i dident need to do any thing to the seat at all apart from trim 5mm off the foam as it was pushing seat up a bit
Old 13-10-09, 09:56 PM   #130
davepreston
which battery and where from
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
Shock spring change andyb SV Talk, Tuning & Tweaking 2 23-03-08 03:51 PM
To change the rear shock, do I need to remove the swing arm? DarrenSV650S SV Talk, Tuning & Tweaking 13 28-12-07 07:42 PM
sv 99-02 shock change French SV Talk, Tuning & Tweaking 4 24-02-07 07:47 PM
change of standard shock riktherider SV Talk, Tuning & Tweaking 17 14-12-06 12:48 AM
