Old 26-07-10, 05:50 PM   #411
Default Re: rear shock change
1mm longer
but looking again at the sheet stick with your stock unit! as the ebay 1 is a 06 generation
Old 26-07-10, 06:18 PM   #412
Rob969
think i'll just have to keep on the look out for the right one to turn up on ebay. Might see if i can get the 08 zx6 one at a better price got to be better than an 8 year old stock one
Old 26-07-10, 06:33 PM   #413
barwel1992
the zx10r shock is still to soft for your weight's...! and has to be the 04/05 shock the other years other are to short
Old 26-07-10, 06:40 PM   #414
Rob969
how are they too short. there 1mm longer than standard
Old 26-07-10, 06:56 PM   #415
barwel1992
oops your right getting confused now, ment they are to soft. the one is the same as stock and the other slightly harder the other harder still. all are to soft like i sead you need 12kg/mm and there isnt any that hard so you go with the next best thing and thats the o4 zx10r shock as its at least got a 10kg/mm spring and slightly longer than stock
Old 27-07-10, 11:11 AM   #416
Rob969
ok found a zx6 shock but it seems to be an 05/06 one and is 1.5mm shorter than stock but slightly stiffer. would the slight difference length really make much difference
Old 27-07-10, 12:07 PM   #417
Davies 52
Hi all,Right then all !!!!!
I HAVE A 2002 CURVY.
I want to know wat shock to change my Oem to
I am 5"11 tall and 14 stone in weight....
What shall i use.I got cash waiting to by a shock.
Lee D
Old 27-07-10, 01:26 PM   #418
barwel1992
yup, im not sure what the ratio is on the curvy think it could be 1:3 ratio so 1mm at shock = 3mm at the back, you really dont want a shorter shock
Lee D
what bike have you got k1-2 or k3+
Old 27-07-10, 04:29 PM   #419
Rob969
anyone know the spring rate of the newer zx6r shocks.
Old 27-07-10, 10:21 PM   #420
TamSV
TamSV's Avatar
Lee D
Depends how good you want it to be and how much cash you've got waiting
Have you read through this whole thread? It'll take some time but you'll probably know the answer by the end.
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
Shock spring change andyb SV Talk, Tuning & Tweaking 2 23-03-08 03:51 PM
To change the rear shock, do I need to remove the swing arm? DarrenSV650S SV Talk, Tuning & Tweaking 13 28-12-07 07:42 PM
sv 99-02 shock change French SV Talk, Tuning & Tweaking 4 24-02-07 07:47 PM
change of standard shock riktherider SV Talk, Tuning & Tweaking 17 14-12-06 12:48 AM
