Old 28-07-10, 02:52 PM   #421
Default Re: rear shock change
been doing a wee bit of research with a suitable shock for my weight
found 2 close to what I need (12kg/mm):
- daytona 600
- Daytona 675
just trying to find out the length. If anyone knows it it'll be greatly appreciated
Old 28-07-10, 02:59 PM   #422
barwel1992
675 06-09 is only 294mm long
Old 28-07-10, 03:01 PM   #423
barwel1992
apparently the d600 is 318
that what i have found any way
Old 28-07-10, 03:01 PM   #424
cheers barwell throught it was sub 300
Old 28-07-10, 03:04 PM   #425
- daytona 600
- Daytona 675
Can you not see a slight physical problem with fitting this shock? Even if the length is correct?
Old 28-07-10, 03:07 PM   #426
barwel1992
lol i just had a ganders and yes a rather small thing but large problem
Old 28-07-10, 03:09 PM   #427
what it'll probably break me back at the first bump
got a decent pic of it it'll be a bit dubious about fit
Old 28-07-10, 03:12 PM   #428
yes, because you'll be riding a hardtail
Old 28-07-10, 03:12 PM   #429
barwel1992
hear is the ohlins unit for the d675
sv shock
Old 28-07-10, 03:14 PM   #430
aye seen tht pic when a rechecked meself
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
Shock spring change andyb SV Talk, Tuning & Tweaking 2 23-03-08 03:51 PM
To change the rear shock, do I need to remove the swing arm? DarrenSV650S SV Talk, Tuning & Tweaking 13 28-12-07 07:42 PM
sv 99-02 shock change French SV Talk, Tuning & Tweaking 4 24-02-07 07:47 PM
change of standard shock riktherider SV Talk, Tuning & Tweaking 17 14-12-06 12:48 AM
