#521 |
I had to jack the bike up after shock change by 25mm as gixer shock is shorter
#522 |
#523 | |
I re-sprung my stock shock which works for me. Others bought Maxton/Ohlins made for an SV Just because you can bodge it in doesn't mean its the right thing to do - if its taller or shorter than a stock one then the geometry is messed up. I have a friend who borrowed a mates bike that had the shock swapped. Problem was that the bike was in New Zealand and the Shock came from the US, where a different bike was known by the same name. So my mate ended up stuck in NZ with 2 broken wrists after he experienced a rather bad Tank-Slapper. Not saying that its going to be THAT extreme fitting the "wrong" part (and many on here have done this and not been injured by it but its your call.
Sent from my PC NOT using any Tapatalk type rubbish!! █╬╬╬╬(•)i¯i▀▀▀▀▀█Ξ███████████████████████████████) |
#524 |
A good quality shock (Ohlins, Penske etc), custom build for your riding style, is going to be the best - but you pay alot of money for it.
In terms of bang for your buck, you can't beat the swap from another bike. So long as the spring rate is right, there's a decent range of adjustability and it's the right length then there's no reason that it would be anything other than an improvement on stock. In terms of length I'd be happy enough to go a bit longer with the shock but I wouldn't want to go shorter and then try and fix it with dogbones - you're messing with too many variables at that stage IMO. |
#525 |
You want much longer.
#526 |
Fitting a far higher quality shock from another bike is not bodging, it's just plain sense if you can't stretch to Ohlins etc. I'd suggest that repsringing the OEM shock is far more of a bodge and certainly half a job; the damper is barely capable of controlling the standard rate spring when new.
#527 |
Well I've bought a gsxr 1000 k6 rear shock, got a months leave coming up so I'll fit it and report the difference.
#528 | |
#529 |
#530 |
Hi all,
just changed the shock on Bullseye for a ZX10R unit-seems much better. Thought i'd put up the part numbers you need for the Kawasaki nut and bolt for the bottom shock mount. Nut 922101139 £1.44 Bolt 921531615 £3.63 The guys at Cradley Kawasaki were fantastic!! Happy racing and riding TC |
rear shock nut and bolt for a diff shock | drag | Stuff Wanted | 0 | 22-04-08 03:52 PM |
Shock spring change | andyb | SV Talk, Tuning & Tweaking | 2 | 23-03-08 03:51 PM |
To change the rear shock, do I need to remove the swing arm? | DarrenSV650S | SV Talk, Tuning & Tweaking | 13 | 28-12-07 07:42 PM |
sv 99-02 shock change | French | SV Talk, Tuning & Tweaking | 4 | 24-02-07 07:47 PM |
change of standard shock | riktherider | SV Talk, Tuning & Tweaking | 17 | 14-12-06 12:48 AM |
