Old 28-08-09, 10:18 AM   #51
Default Re: rear shock change
I have 05-06 ZX6R shock fitted. Bit short but it works OK.
Old 28-08-09, 10:26 AM   #52
dyzio
dyzio's Avatar
Originally Posted by Bikermike59 View Post
Better get the dremel out then!
Honestly, the cutting isn't that hard, but you'll do better with a Stanley knife.
Is that the C1H? Yours looked similar to what I had. Made the bike a wee bit lower.
Old 28-08-09, 10:29 AM   #53
C1H aye.
SRAD750 shock is way better length, but too soft.
Old 28-08-09, 11:05 AM   #54
Lucas
I'm just about 11st, will C1H be a bit too stiff having a rate of 9.7kg/mm (542lb/in)?
SV's being 9.1kg/mm (510lb/in)will there be a big difference?
I think am happy with sv's spring rate, but want better damping/rebound.
Old 28-08-09, 11:15 AM   #55
Mr Speirs
Mr Speirs's Avatar
It won't be too stiff you will be fine with it and the adjustable compression damping and rebound will make it work much better than the sv shock for you.
Old 28-08-09, 11:17 AM   #56
If I was 11st and never took a pillion, I would use SRAD750 one all day.
Old 28-08-09, 11:31 AM   #57
Lucas
no SRAD750 shock on evil bay, not even any SRAD750 related stuff where else can I find one?
Old 28-08-09, 11:32 AM   #58
Lucas
i may go for it, depending on if I find anything on those SRAD750
oh, is £50 a good price for a C1H?
Old 28-08-09, 11:33 AM   #59
http://cgi.ebay.co.uk/Suzuki-GSXR750...d=p3286.c0.m14
What's that then, a paperweight?
Old 28-08-09, 11:34 AM   #60
Lucas
silly me
cheers!
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
Shock spring change andyb SV Talk, Tuning & Tweaking 2 23-03-08 03:51 PM
To change the rear shock, do I need to remove the swing arm? DarrenSV650S SV Talk, Tuning & Tweaking 13 28-12-07 07:42 PM
sv 99-02 shock change French SV Talk, Tuning & Tweaking 4 24-02-07 07:47 PM
change of standard shock riktherider SV Talk, Tuning & Tweaking 17 14-12-06 12:48 AM
