Old 14-09-09, 07:05 AM   #71
Domas
Default Re: rear shock change
Nice.
Btw how do you adjust preload on GSXR shocks. The old adjuster from SV doesn't work. Do you buy one, make one or use some other method like screwdriver and hammer?
Mine is still a bit nervous in corners, need to set the sag right as the back end is way up I think. Adjusted oil weight, height and emulator preload 3rd time now. I'm getting close
Old 14-09-09, 12:06 PM   #72
7755matt
Mini hijack. If I'm just under 16stone fully kitted (obviously it's really heavy kit) would the 05/06 ZX6 shock be best, or something beefier?
Old 14-09-09, 12:10 PM   #73
Luckypants
Luckypants's Avatar
ZX6 / ZX10 Shock is the right length for the curvy but not the pointy, so what bike you got?
Old 14-09-09, 12:12 PM   #74
7755matt
Sorry. Keep forgetting that. It's a curvy
Old 14-09-09, 12:18 PM   #75
Luckypants
Luckypants's Avatar
Well you could read the thread.....
03-06 ZX6 (636) shock or 04-06 ZX10 shock fits great on a curvy and is about 10% stiffer than stock. I weighed about 16st in gear and zx10-r shock worked really well in the bike.
Old 24-09-09, 07:46 PM   #76
LiamH
New SV owner here....hello!
Just looking at the lists of shocks (here) to choose one for my curvy racebike. Just wondered if any are easier to fit by spacing out the battery box than others. ZX6R looks like the reservoir is smaller than the K8 GSXR...or it might just look that way.
It's got an SRAD shock at the moment. Way too soft but goes in without cutting the battery box, so I'd like something similar sized.
Old 24-09-09, 09:36 PM   #77
Razor
What about one of these?
Old 25-09-09, 07:50 AM   #78
LiamH
Originally Posted by Razor View Post
Thanks for the link. Looks nice, but only adjustable for rebound damping.
Old 25-09-09, 09:23 AM   #79
And it is emulsion shock which is not good. Edit: maybe not
"Rebound" damper there will probably be bleed in both directions.
Old 27-09-09, 10:31 PM   #80
barwel1992
can some one post a pic of the cut battery box ? or will i not have to cut it on a k3 with a gixxer 1000 k5 shock ?
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
Shock spring change andyb SV Talk, Tuning & Tweaking 2 23-03-08 03:51 PM
To change the rear shock, do I need to remove the swing arm? DarrenSV650S SV Talk, Tuning & Tweaking 13 28-12-07 07:42 PM
sv 99-02 shock change French SV Talk, Tuning & Tweaking 4 24-02-07 07:47 PM
change of standard shock riktherider SV Talk, Tuning & Tweaking 17 14-12-06 12:48 AM
