Old 04-06-10, 02:05 PM   #141
barwel1992
Default Re: Aftermarket brake disc opinions?
Could be pistons that are a little, rough. Dont think anyone but brembo use teflon coating?
All I can say is WOW. And that I certainly do need my forks revalving. ha ha.
Flash git
Old 04-06-10, 02:08 PM   #142
ThEGr33k
I would get forks sorted before engine tuning.
Its still not running right though, think it must be fuelling issue. Damn it. I might be able to afford both though so shouldnt be a biggie.
Old 04-06-10, 02:47 PM   #143
AndyBrad
credit card
Old 04-06-10, 04:09 PM   #144
ThEGr33k
Meh, naa. I hate debt. I do have money saved but that is just a buffer, incase.
Old 05-06-10, 09:11 AM   #145
Forks are cheap part. Just need some oil and maybe springs.
If rebound stack is too stiff you may have problem with packing*. Are you sure it is brake dive clonking directly?
*Not THAT packing problem
Old 05-06-10, 09:38 AM   #146
ThEGr33k
Yea, its not rebound I don't think. Funny you should mention rebound clonk, my brothers mountain bike forks do it with too much rebound, or any at all really. What is it that causes that, got more detail, how to fix? taa
Anyway, back to motorbike. Certainly is bottoming out, not rebound, it only happens when the forks stop travelling
Old 05-06-10, 09:49 AM   #147
barwel1992
its the oil damper rod thing hitting the oil i think ? that causes the clunk
and TEGr33K when you finish with the other master give me a shout and i will take ure old one off you (have the cash now lol)
Old 05-06-10, 09:51 AM   #148
ThEGr33k
OK, cool. Should be ok to send on this week.
So basically the rebound needs more oil?
Old 05-06-10, 09:57 AM   #149
barwel1992
yay lmao
no the damper rod has a disk with holes (im lead to believe) and this disk hits the oil its a bit like when slapping water with your hands then the oil is forced through the holes and because the oil is think and the holes are small forces the forks to slow down < wrong terminology (dampening)
not sure if thats right but its somthing along those lines, wheres yc when you need him
Old 05-06-10, 10:17 AM   #150
I have no idea about MTB forks. They use some weird setup. If they are clonking when fork begins rebound it could be some seal has freedom to move up and down a bit like SV ones or it could be something loose.
I know it is not rebound clonk you have but if you have too much rebound fork cannot recover in between bumps so you use up all your travel which can make you bottom out when normally it would be fine.
Brake disc jack930 Stuff Wanted 2 13-10-09 10:00 AM
MOT - brake disc thickness DarrenSV650S Bikes - Talk & Issues 18 24-01-09 12:03 PM
Just ordered a set of brake hoses - opinions? sv_rider1990 SV Talk, Tuning & Tweaking 8 24-06-08 12:15 PM
front brake disc leemole Stuff Wanted 1 17-08-07 06:52 PM
Aftermarket brake pads.. verticaldip SV Talk, Tuning & Tweaking 5 14-06-05 08:54 AM
