Old 23-12-07, 05:41 PM   #11
viva_unix
Red face Re: is it correct oil?
Originally Posted by Well Oiled View Post
SF and SG are indications of the oil quality, as defined by API (American Petroleum Institute). The S stands for Spark ignition (petrol engine). There are 'C' specifications for Compression ignition (diesel). Somewhere on the can will be a list of specifications that the oil meets.
The F and G are the quality level. Each time the spec is revised and improved it goes up a letter, so SG is a more recent and higher performance spec than SF, but they are both old specs. The latest is SM. If the second letter on your can is higher than G it will be fine as the later specs cover the requirements of the earlier ones.
Hope that helps Keith
OK. Got it. Thank you!
Do i have the correct battery? andyfordceo SV Talk, Tuning & Tweaking 3 01-11-08 12:13 PM
Is my licence correct??? neilhatch Bikes - Talk & Issues 4 25-03-07 09:08 PM
PSI gauges which one is correct ? SpankyHam Bikes - Talk & Issues 13 18-07-06 06:58 PM
The correct way to filter... caines Bikes - Talk & Issues 15 30-11-05 09:44 PM
