#11 |
I could see the butterflys moving about as the bike was warming up. They're constant now and only move as I open the throttle.
Is this where you mean? ![]() Another thing. When I raise the tank the overflow keeps dripping. I brimmed the tank earlier so is that why? |
#12 |
That temp sensor reads infinate from cold up to at least 50C.
#13 |
#14 |
Thats not the ECU temp sensor.... That is the rad temp sensor. (for the fan)
Usually ECU temp sensors are on the thermostat housing, and has a green connector. (if not on thermostat housing it will be somewhere on the engine.) |
#15 |
Looking through my manual...... is it the engine coolant temperature sensor I need to check or the thermostat ?
Whichever it is, it says I'll need to drain the coolant to test it ![]() |
#16 |
the engine coolant sensor is the one with the ECU uses to calculate the fueling.
The rad sensor tells the fan to turn on. coolant change isnt much of a headache, but then new sensors aren't massivly expensive either... can you not test as shown above (on the right sensor?) Last edited by injury_ian; 10-11-08 at 08:55 PM. |
#17 |
I'm not sure. It says in the manual that it should be certain resistances at certain temperatures. So if I was doing it with the sensor still in the bike I would need to know what temperature the bike was at. But if the sensor was disconnected, wouldn't that kill the temp reading on the clocks?
Manual- ![]() |
#18 |
mmm faffing-ness,
what year is your bike, I wouldnt expect the temp sensor to fail that soon. does your bike reach 70+C with in about a mile? Could be a lazy thermostat keeping the bike cooler (hence mixture richer) than it should? |
#19 | |
Yeh it gets up to temperature pretty quick |
#20 |
Excuse me for intruding on your (increasing) grief, but being asked to comment on one spark plug's condition, without knowing a whole host of other info, is a really good road to fixing all sorts of problems that don't really exist! A plug can look sooty-black from a whole host of quite normal running conditions - not least from that suggested by Bibio in the first place. If you took that plug out on a cold day, when the engine had been ticking over for three or four minutes - even if you had revved it up a few times, then that's pretty much how a normal plug can look.
So ask yourself: was it running badly when you took the plug out, or quite normally? Was there something going on that made you suspect a problem? |
Rate my plugs? | AndyBrad | SV Talk, Tuning & Tweaking | 6 | 26-11-08 04:33 PM |
spark plugs | daddy_sperm | SV Talk, Tuning & Tweaking | 12 | 01-03-06 06:12 AM |
Spark Plugs | fred_dillon | SV Talk, Tuning & Tweaking | 5 | 19-06-05 06:45 PM |
Spark Plugs | valleyboy | SV Talk, Tuning & Tweaking | 15 | 18-05-05 07:51 AM |
spark plugs | weegaz22 | SV Talk, Tuning & Tweaking | 4 | 04-08-03 05:04 PM |
