#11 |
I believe so.
K1-K2 had black alternator + clutch cover. K3 got silver. No pair system, so looks like those are curvy cam covers.
#12 |
99-2000 were black, then they changed to silver in 2001
so its either 2001 or 2002 |
#13 |
![]() ![]() Thanks again for the curvy answer. The so called "running order" engine wasn't really in running order, the cam was 180 degrees wrong on the rear cylinder made a lot of noise, thought it might have been damaged ![]() ![]() |
#14 |
'01 or '02 engine with '99 or '00 covers, the cylinder head and assembly are definitely from a Curvy.
#15 |
[quote=aln;1722300]my engine number is:
P503 171255 All I can figure out is that it's a P = 600 CC and four stroke twin (5) and 03 is year. My K2 SV650N bought Sept 02 has engine number 195761 if that's any help. |
#16 |
just out of intrest what are you putting the engine in?
#17 |
#18 |
#19 |
He's got a Curvy according to his previous thread in the wanted section a while back.
#20 |
All the above is true, but the most obvious difference between curvy and pointy engines is the clutch cover - no external plastic section on FI motors.
Curvy fork identification? | herbie | SV Talk, Tuning & Tweaking | 6 | 05-03-09 12:24 AM |
Lower fairing identification... | Gnome | SV Talk, Tuning & Tweaking | 4 | 29-03-08 09:42 PM |
Engine braking... any hazzards engine wise? | John 675 | SV Talk, Tuning & Tweaking | 21 | 28-03-08 07:20 PM |
SV1000 part Identification | Mark_h | SV Talk, Tuning & Tweaking | 15 | 22-11-07 12:23 PM |
Ohlins Shock (model identification) | ASM-Forever | SV Talk, Tuning & Tweaking | 2 | 01-04-07 11:27 AM |
