#11 |
Do this.
#12 |
Read the OP folks, "The disk only goes half down onto the pads as its diameter is much smaller than the old one. "
Unless the previous owner of your bike did something odd like fit another bike's wheel or modified the position of the caliper (and fit a bigger brake disc to "correct" this), you clearly have the wrong brake disc. Ask the seller for an explanation/replacement/refund. |
#13 |
JC is correct. Diameter is smaller..
I've taken photos to show it better. As for grease on the disk, nope no grease, yes did clean it, and no that didn't make it smaller! ![]() ![]() Cheers |
#14 |
two different sizes!
#15 |
yup, question is, how much less effective is the brake with only that much of the pad on it?
#16 | |
Personally I'd be inclined to go and purchase the correct size disk...
#17 |
definately do not leave them on, they are not right
#18 |
pretty sure I will be buying new disk within few days (so much for saving money). So from this I guess you can't raise the calipers / pads to fit onto disk better.
#19 |
You could I suppose but you would probably run into interference issues, end up with an overall less powerful brake. And spend ages at it.
#20 |
Looks like a pointy rear disk on a curvey to me. To see what other Suzuki models rear discs fit your bike and this link may be useful (also good for people who like to play "mix & match with wheels, forks etc")
http://www.allbikeengineering.co.uk/abe/brakediscs.pdf With this info you can widen your searches on Ebay and if the seller doesn't list the size you know what to ask. Personally I wouldn't run that disc caliper setup (not because of reduced efficiency - I have actually converted my curvey rear brake to a pointy because I find the curvey brake too powerful!), because it will be trying to skew the pistons in the calipers. |
Rear Brakes, Disc and Pad Replacement - Can I? | krhall | Bikes - Talk & Issues | 24 | 08-05-08 04:06 PM |
front brake disc | leemole | Stuff Wanted | 1 | 17-08-07 06:52 PM |
loose brake disc | leemole | SV Talk, Tuning & Tweaking | 8 | 16-08-07 11:16 AM |
Brake Disc thickness | andyb | SV Talk, Tuning & Tweaking | 7 | 14-11-06 10:49 AM |
Front Disc Replacement? | ryancor | SV Talk, Tuning & Tweaking | 12 | 04-04-06 03:44 PM |
