Old 01-04-09, 09:58 AM   #11
21QUEST
21QUEST's Avatar
Default Re: Bike Not Starting
Originally Posted by flymo View Post
Because powering the starter only does just that, if you have a loose connection that effectively means the ignition circuit is not powered (clutch switch/kill switch etc) then you'll spin the engine but get no spark.
hah, feel a right dafty now hehe..... obvious when you think about it huh Cheers : ) .
Dizzy, you are helping .
Okay guys thanks for all the suggestion so far. I'm going to go out and start stripping. I shall be keepign an eye on thread so please keep them coming
Ben
Nemo me impune lacessit.
Old 01-04-09, 09:59 AM   #12
Nicky S
Nicky S's Avatar
flymo is right... but id say check everthing on the handle bars before you go riping your bike apart to find a broken wire
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 01-04-09, 10:05 AM   #13
flymo
flymo's Avatar
+1
Old 01-04-09, 08:56 PM   #14
BILLY
Just scrap it Ben and use the thou instead!!!! Anyhoo i thought you was buying a scooter for work again?? cause you had gone all mamby pamby
Old 02-04-09, 07:28 PM   #15
21QUEST
21QUEST's Avatar
Gone all mamby pamby? hehe
Oh, yeah, still getting a Scooter. On the 650, it's now a bit too easy taking the scalps of the Sunday/fair weather warriors. Soooo I'm looking to give them more of a 'head start' and i reckon, a Scoot would be perfect
So you gonna be of any more help?
Ben
Old 02-04-09, 07:36 PM   #16
21QUEST
21QUEST's Avatar
Ellooo guys.
Still no joy. Checked all the main connecting blocks ie those in the headlight bowl, one underneath the tank and the two switch gears.
Tried different switch gears and CDI too. I left the best till last (yup forgot about 'simple stuff first')...that'd be the checking for a spark from the plugs then. No spark from either.
Any more thoughts?
Ben
Old 02-04-09, 08:16 PM   #17
zadar
yes and no. if you have power to starter relay it means there is power coming in and out of kill switch. when motor is turning and everything works but you have no spark than either you got no signal to cdi (resistor in ignition, pulse generator) or one of those wires has bad connection somewhere.
Old 02-04-09, 09:13 PM   #18
flymo
flymo's Avatar
I dont think that was the case though, maybe I misunderstood the post but I thought 21 had powered the starter by means of jump leads to the starter motor terminals. If thats the case it'll do nothing except spin the motor.
Old 02-04-09, 09:23 PM   #19
flymo
flymo's Avatar
which model bike is it?
Old 02-04-09, 09:34 PM   #20
21QUEST
21QUEST's Avatar
Flymo, it' a 99 Naked 650
And yup, you are correct...I did also power the starter motor straight from battery.
Ben
Bike not starting. svdemon SV Talk, Tuning & Tweaking 15 22-08-08 11:29 AM
bike not starting Ash_sv650 SV Talk, Tuning & Tweaking 3 26-06-08 10:48 PM
Bike not starting. help. bad-sv650 Bikes - Talk & Issues 23 13-01-08 03:18 PM
HELP!!! BIke not starting!! riktherider SV Talk, Tuning & Tweaking 10 08-06-05 02:14 PM
Bike not starting. valleyboy SV Talk, Tuning & Tweaking 2 19-02-05 08:49 PM
