Old 15-12-09, 08:01 PM   #11
sundog
Default Re: Clutch cover.
Exactly the same.the leak on mine is now only minor but still there.Is there a good gasket sealer around and do you use it with the o-ring?
Old 15-12-09, 08:13 PM   #12
5hort5
Like I say I used bathroom silicone from tops tiles, rated up to 150 degrees and it works fine, I think most will tbh. If the oil and cover get above that then I think you have a major issue
5hort5 is offline   Reply With Quote
Old 15-12-09, 10:21 PM   #13
sundog
Ok thanks for the advice
Old 15-12-09, 10:45 PM   #14
beabert
had same issue last week, gasket sealant from halfords. £5.50 i chopped the oring smaller and placed the cut at the top.
http://www.halfords.com/webapp/wcs/s...egoryId_165691
Old 20-12-09, 05:41 AM   #15
bighammer
Junior Member
Drive the metal bushings out of each screw hole and take a fuzz off the length. Reassemble and hopefully you have a low cost (no cost) fix.
bighammer is offline   Reply With Quote
Old 20-12-09, 07:13 AM   #16
MattCollins
This (edit: warped cover) is not such an uncommon problem across different makes and models.
For my money, I'd go for a Woodcraft (or similar) billet cover. The price might sting a little initially, but the problem is fixed permanently and it is also a nice bit of bling.
Weepy clutch cover noob-saibot SV Talk, Tuning & Tweaking 28 17-12-09 08:22 PM
Clutch Cover carsounds_dan SV Talk, Tuning & Tweaking 17 12-06-08 04:27 PM
Clutch cover. scottjames SV Talk, Tuning & Tweaking 8 16-04-08 11:30 AM
clutch cover leaking habbie SV Talk, Tuning & Tweaking 0 06-05-07 02:07 PM
cracked clutch cover alka SV Talk, Tuning & Tweaking 3 28-06-05 09:34 AM
