Old 12-09-09, 07:36 PM   #11
drag
Default Re: Lifespan of Honda CBR600RR reg/rec tested.
http://eviltwinsbk.com/forumz/index.php?topic=276.0
thats the original post, you can see the loom made up, and how it compared to where you can order it on the other site.
bit more help with the 08 reg/rec which shoudl be on ebay
http://blip.tv/file/2375590/
use this in ure ebay search
CBR* ("Regulator", "Rectifier") ("05", "06", "07", "08", "09", "2005", "2006", "2007", "2008", "2009")
it'll turn up loads
Old 12-09-09, 07:52 PM   #12
OK, the one I've used (both times) is the FH008EB, I think. Worth mentioning that the bolt holes are in the perfect place and though it's physically larger than the SV one, it still fits under the plastic of the curvy SV. You need to chop the plugs and rewire it one way or another, I just soldered on the plugs from an old SV reg/rec- though that thread does seem to suggest that it's better to remove the plugs as a point of failure... I'll be honest, never occurred to me but I'd sooner have the simple removal options myself I think. But I'm no spark, that's for sure!
I've used some of those plugs previously, I think, Frosts sell something very similiar, fully waterproof etc. But not on the SV... Almost none of hte stock SV plugs have any weatherproofing after all. But it certainly can't hurt, and they're good kit as far as I can tell.
Old 14-09-09, 06:48 AM   #13
ixlr8
I put a Yamaha MOSFET in as my 3rd replacement (2 OEMs before) but hoped they'd last forever . We'll see.
ixlr8 is offline   Reply With Quote
Old 14-09-09, 07:36 AM   #14
Viney
Default Re: Lifespan of Honda CBR600RR reg/rec tested...
Originally Posted by Alpinestarhero View Post
I have replaced my reg/rec once, about 17,000 miles ago now. How can you get through so many? What factors affect the life of a reg/rec?
I am going to tempt fate. I have only had 2 in 62000 miles.
Old 14-09-09, 07:38 AM   #15
Dave20046
Dave20046's Avatar
My original lasted about 9k
Old 14-09-09, 08:28 AM   #16
glang
Ive had a bit of experience with failing regs/rects so heres my thinking for what its worth:
They operate with 3 phases so usually only one phase fails allowing an AC component in the battery charging current and as batteries apparently dont like this they
promptly fail. Often the owner replaces the reg/rect but as the battery is knackered it doesnt hold its charge very well and when it goes flat the bike is bump or jump started. Now I believe this is a complete no-no because the reg/rect than has to supply charging current to a flat battery (often with the bike stationary and without a cooling air flow) so risking damaging it and starting the vicious circle again. Sometimes the battery is replaced but if charged with a dodgy reg/rect this circle will continue uninterrupted!
I think the answer is to confirm that the reg/rect has failed (not always easy), change it and if the battery still discharges replace it directly before trying to start the bike. Also running temperature of the reg/rect seems very important so if it can be replaced with one of a larger capacity and/or bigger cooling fins or relocated to a cooler area all the better.
Old 14-09-09, 06:04 PM   #17
Oh, I meant to add, I love my Yuasa YTZ-12S, god knows how many times it's been flattened completely- a good few dozen- but it still keeps coming back to life, and seems as good as it was when I got it 4 years ago. Good kit.
Old 24-09-09, 10:27 PM   #18
transparent_opacity
Funny, I've had 2 Suzukis & 2 Hondas, but the only bikes I've had to replace the Reg/Rec on were the honda! :P
Old 13-10-09, 04:35 PM   #19
zunkus
OK, the one I've used (both times) is the FH008EB...
What year and bike does this come from?
I've searched parts fish on web and found different R/R's for CBR600RR's throughout the years. Also their part numbers are something like:
SKU: 31600-MFJ-D01
RECTIFIER ASSY., REGULATE (Honda Code 8593790)
Is this different than PN?
I'd like to buy the correct part and not an over large item which I'd have trouble fitting. Can you help me out a bit Northy? Thanks mate.
Is this ok for instance?
http://cgi.ebay.com/ebaymotors/HONDA...11410006r15042
Old 13-10-09, 06:59 PM   #20
Biker Biggles
Biker Biggles's Avatar
That one looks like the one I fitted to my curvy a couple of years ago.Its been fine sinse.You just need to splice the output wires together because there are too many of them.It bolts straight on to the same mountings if you remove that backing plate.
Ducati 848 / Honda CBR600rr sauluk Bikes - Talk & Issues 20 28-07-09 07:00 PM
What is the Average Chain Lifespan? COLZO SV Talk, Tuning & Tweaking 16 29-01-09 08:24 PM
Honda CBR600rr VS. Triumph Daytona 675 Jelster Bikes - Talk & Issues 60 08-08-07 07:49 PM
How long is a helmets lifespan? Monkey6879 Bikes - Talk & Issues 28 05-02-07 01:11 AM
anyone know the lifespan of the clutch, should I change it? GooseSVSK2 SV Talk, Tuning & Tweaking 2 20-01-06 09:47 PM
