#11 | |
#12 |
^ lol im not that stupid
#13 |
have you not seen the thread?
Atleast one members done it.
#14 |
yup i have but i dont clean my chain when its spinning, jus spray the lube on with it spinning
#15 |
Not sure what I've done
![]() Checked chain everything looked ok. Stuck it up on the stand to get a better idea where the noise was comming from. Engaged 1st, let clutch out slowly, back wheel spinning, as I let the clutch out the chain started bouncing. Which sort of indicated that some of the links were a bit tighter than they should be. So thought OK, I'll go get a new chain & sprocket set. So put bike back in garage. Stuck it in gear, stall, don't know what I've done but now the clutch doesn't disengage completly. Engine off, in gear, clutch in, there is a definate resistance to roll. adjusting the cluch cable makes no difference. EDIT: It would appear that the clutch isn't doing anything. Help! Last edited by Grant66; 21-11-09 at 01:53 PM. |
#16 |
^ doble check the chain tension to make sure its not to tight and check the clutch cable hasent falen out of place (where it meats the leaver and the clutch end)
#17 |
Clutch cable is in there, push rod thingy rotating. Chain tension OK. 25mm ish.
#18 |
If you wanna have a look, the clutch cover is only a rubber oring so no time consuming gasket stripping needed. Ofcourse you will have to drain the oil, unless the oil line is below on the side stand.
Im having an odd clutch dragging issue and it isnt my cable or mechanism either. |
#19 |
#20 |
could you of worn your clutch out?
or maybe clutch springs gone? do you change gear without the clutch much? could you of damaged a gear in the gearbox if its only at low speeds? will wait to be corrected now on reasons why its not the gearbox. |
total mechanical amateur - Clunking noise when accelerating? Any Ideas | TechJinx | SV Talk, Tuning & Tweaking | 10 | 23-06-09 01:27 PM |
It still makes that clunking fork noise. | Tony_BLY | SV Talk, Tuning & Tweaking | 29 | 01-03-09 10:48 AM |
clunking noise under braking | nik_nunez | SV Talk, Tuning & Tweaking | 24 | 28-08-08 04:24 AM |
Clunking noise on GSXR750 | rubberduckofdeath | Bikes - Talk & Issues | 8 | 06-06-08 05:19 PM |
clunking chain noise | steveg | Bikes - Talk & Issues | 4 | 23-03-08 10:39 PM |
